carbon fiber console bezel
If to want a gm product speak to kevin at parts taxi. I believe his prices are always best. Or you can get one that was refinished in hydro carbon in which case I would contact empire corvettes who I believe has a new name of performance corvettes. Or contact TKO for hydrocarbon as well.
Hydrocarbon is basically a wet graphic overlay process that is applied to the molded plastic bezel to give it an appearance of carbon fiber. As opposed to Carbon fiber which is a material constructed of fibers of carbon formed in to sheets and molded with a reinforcing agent such as a polymer, most often an epoxy. All of the OEM components are a form of hydrocarbon in that it is a decorative treatment applied to the surface of a molded plastic part. There are a few companies out there that make actual carbon fiber components to fit various places on the Corvette.
The one from parts taxi is original equipment direct from gm. The one from tko or any other hydro vendor is also gm part just refinished in hydro carbon. The part is the SAME.... The only difference is that Kevin's come from the factory pre painted and the ones from tko are painted after the part is taken out of another or (doner) vehicle which is why you can either send them yours to get refinished or send your original back to them after you recieve your new item.... Either one you decide to go with goes through the same hydro carbon process...
Former Vendor
Kevin
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
We start with genuine GM parts and then apply a finish to it using the same process GM uses ( for the 2008-2012 centerl consoles).
Here is a 2006 center console we did where we applied a GM 2010-2012 4 LT finish to it. (We also applied accent stainless trim rings too)
Below is a matching Gauge Bezel ..
If you have a 2008-2012, we can match your factory GM console.
If you have a 2005-2007, We can apply any finish you want.
We can do the GM 2010-2012 1LT, 2LT & 3 LT finish, the GM 2008-2009 finish and our Gun Metal carbon fiber too..
To check it all out, click the link below then click the years to see what you would like.
http://store.tkoperformance.com/cuinpi.html
Feel free to call us toll free if you have any questions 800 778 9898
Ed
__________________
Serving The Corvette Forum For 21 Years!!
Allow us to add you to the list of extremely satisfied customers.
Order Securely Online 24/7: http://tkoperformance.com/index.html
Feel Free To Contact Us By Phone: 1800 -778- 9898 Monday- Friday 9:00am to 4:30pm
Click Here: http://www.facebook.com/pages/TKO-Pe...e/367433626633
