2008 LS3 problem
Old 05-30-2012, 08:01 AM
Raymond44
4th Gear
Raymond44's Avatar
Default 2008 LS3 problem
Upon returning from a 10 day vacation, the (new) battery on my 2008 convertible was dead. I charged it overnight, but all I get is a clicking sound when I try to start. I tried to jump it with my other car but still getting a clicking sound. The check engine light is showing on the dash.
Any suggestions will be truly appreciated!
Old 05-30-2012, 08:06 AM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Battery has been abused to death. Disconnect battery and I bet it still won't take a charge because it is shorted.
Old 05-30-2012, 08:35 AM
JohnAE455
JohnAE455's Avatar
If you already didn't do this when you changed the battery try cleaning the cable ends and battery and make sure they are reasonably tight, don't overtighten. Since you charged it overnight and had the same problem and it won't start when jumped I suspect the battery terminals or cable ends are the cause. It should start when jumped even with a bad battery but won't if the connections are bad. To be sure you can take your battery to an auto parts store and have them check it out if cleaning the connections doesn't help. You could also check the car body connection for the negative cable. Good luck.
Old 05-30-2012, 08:45 AM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
in add. to above, ck to see (since it's a new batt.) that you have the proper cable nuts. they're easily lost when taken off completely (not necessary to do with batt. replace.) and if not on and tight, there's no completed circuit. finally, since you've been on here a year, you may want to read up on batt. "maintainers." if you ask me, it's very important to the life of your car batt.
Old 05-30-2012, 09:03 AM
Raymond44
4th Gear
Raymond44's Avatar
Default LS3 won't start
Thank you guys for your quick suggestions. Just for clarification, my battery is 2 months old, Optima yellow top. The cables and connections are clean, snug, no missing nuts. Been driving the car with no problems until I left it for 10 days. Next time I know to plug in a battery tender.
I will have the battery checked to see if it's shorted, as suggested by Fort.
Old 05-30-2012, 09:08 AM
AORoads
AORoads's Avatar
St. Jude Donor '15
"In honor of jpee"
Hope it all works out. Tell us, btw, if it is a failure of the battery. I doubt it but it could be.
Old 05-30-2012, 09:37 AM
boraxman
boraxman's Avatar
Sounds like you may have got a defective battery...get it checked out.
Old 05-30-2012, 09:45 AM
FortMorganAl
Originally Posted by Raymond44
...Just for clarification, my battery is 2 months old,...
Oh, that's different. Even abused batteries shouldn't short in just 2 months. Maybe try the "reboot" that has absolutely no reason to work but people keep claiming it does. Disconnect and reconnect the battery. Maybe the low voltage confused one of the computers and it wouldn't turn off and wouldn't turn fully on either. Charger isn't capable of charging the battery at the same time it is running the computer.
Otherwise I'm back to bad battery even though it is only 2 months old.
Be sure to let us know what you find.
Old 05-30-2012, 09:51 AM
GARYFINN
GARYFINN's Avatar
Location: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Received 1,142 Likes on 592 Posts
Just because a battery is new doesn't necessarily make it good.One time I had to take 2 back to get a good one. CHECKOUT THE BATTERY.
Old 05-30-2012, 10:05 AM
rjmij
rjmij's Avatar
Bad Battery. Return it, that should not happen to a Optima Yellow Top.
Old 05-30-2012, 01:29 PM
Raymond44
4th Gear
Raymond44's Avatar
FortMorganAl,
You were 100% correct...the 2 month old Optima Yellow Top is dead.
The auto store checked it and replaced my battery, and my Vette is alive again.
I must say, however, that the battery was never " abused".
The car was just parked in the garage for 10 days, and it died.
Next time I'll have a battery tender plugged in.
Thank you all for your responses.
Old 05-30-2012, 01:46 PM
TJay74
TJay74's Avatar
FortMorganAl,
I can tell you from a Optima thread on Ls1.com, Optima considers that battery abused if you didnt have a charger on it. They have seem to become sticklers now a days on what you do with a battery when not in use.
I wont use them anymore, the last 2 I had died with in a year, both of my dads batteries in his boat died with in a year. I still to Sears AGM or Orielly's AGM now.
Old 05-30-2012, 03:20 PM
Ratchet Thunderbolt
Ratchet Thunderbolt's Avatar
Good call on getting the battery checked. Even new batteries can go bad.
Old 05-30-2012, 03:51 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
FortMorganAl,
Other than a battery that had an early failure, most of the issues noted here, are from cars that don't get driven much or often. The DD guys usually have very few battery problems.
Old 05-30-2012, 04:20 PM
C7-Beast
C7-Beast's Avatar
My 08 does not given driven a ton. When I bought it new it had 2 miles on it. Almost 5 years later and I have 6K miles and on the original battery. I leave mine on a tender when not in use. If it dies now, I feel I'm luckier than a lot of folks here.
Old 05-30-2012, 09:20 PM
AORoads
AORoads's Avatar
St. Jude Donor '15
"In honor of jpee"
FortMorganAl,
Good grief, 2 mos. old battery dies. Glad it's resolved.
Yes, consider yourself darned lucky, imo.
Old 05-30-2012, 09:33 PM
Dave Carney
Dave Carney's Avatar
Got one month out of my Optima yellow top...never again.
To 2008 LS3 problem
Quick Reply: 2008 LS3 problem
