Change Engine Oil Warning
Old 07-08-2012, 08:54 PM
Bailey15
Bailey15's Avatar
Default Change Engine Oil Warning
Yesterday, I was driving home and the "Change Engine Oil" warning came on.
I found this to be odd because I just got my oil changed about a month ago and I have not driven it that much since then. My commute to work is about 10-20 minutes each way.
When I got home I checked the oil levels and the were fine. I also checked under my car to see if I spotted a leak and I saw nothing.
Has anyone had this warning come on and what does it mean?
Old 07-08-2012, 09:04 PM
Keppler
Keppler's Avatar
It means the oil life monitor reached 0% and you should change the oil.
When you had the oil changed a month ago did they reset the oil life monitor to 100%?
If the oil on the dip stick looks clean the shop probably did not reset the oil monitor.
Old 07-08-2012, 09:09 PM
obxchartercaptain
obxchartercaptain's Avatar
FL Events Coordinator
Old 07-08-2012, 09:12 PM
SSTEVEGS
SSTEVEGS's Avatar
It means nobody reset the oil change setting on the DIC. It's easy to do yourself - go to the oil life setting and hit "reset"
Old 07-08-2012, 09:28 PM
Bailey15
Bailey15's Avatar
Appreciate it!
To Change Engine Oil Warning
Quick Reply: Change Engine Oil Warning
