Help: Left headlight's front leading edge protrudes 3/8" too high..
Hi Guys, I've searched & searched & still need some help.
My driver's side headlight's front (leading) edge, sticks up about 3/8+" higher than it should, & for the life of me I can't figure out why. I've removed the inner fender liner & lightbulb access flap, so that I could fully slide/adjust the light housing around on it's plastic shelf, but I just can't get that front edge to fit lower(correctly). The entire assembly fits very well in the cutout, proper gaps & fitment all the way around, etc...it's just that front leading edge portrudes much higher than it should.
I don't think the front fender/fascia is misaligned or anything, & I can't feel the driver's side fender/fascia moving up/down any more than the passenger side, but now I'm wondering if there's some headlight guide or clip, or some front fascia guide or clips, that positions the fascia, or the headlight assembly within the front fender's light assembly coutout?
Here's the wrinkle; The passenger side headlight is perfect, perfect gap, fits nice & flush, etc., but I just noticed the driver's side looked tweaked the other day, right after I'd tried to drive the car up on ramps. They both skidded forward & the front fascia got hung up(pushed upwards hard) when all its' weight was stuck on the highest part of the ramp. Which makes me think I tweaked something in how the fascia mounts on the front, or how the headlight sits on that shelf, or mates to the front fascia.
I really, really don't want to remove the headlight or the front fascia, as everything else fits/feels perfect, so I'm hoping someone with the same issue has some advice. Many thanks for any input or advice you can offer.
Many Thanks NW94Z, I didn't realize those three mounting posts could screw in/out of the headlight assembly & it's entirely possible I turned them by mistake when attaching/reattaching those three 10mm bolts.
Question, do you think it would it be possible to turn these mounting posts without removing them from the car, ie; from under the vehicle (removing the inner fender liner, etc.) & turning them with pliers or vice grips on the end of the post?
Just don't unscrew them to far or they will come out of the headlight assembly and you won't be able to get them back in without pulling the headlights. I only had to adjust mine by about a 1/4 inch. Raising the rear of the headlight will help drive that front edge down and make a better seal with the fender at the same time.
