help,had enough
help,had enough
maybe some one can help me. I just bought a 2010 gs with 2,700 miles. i took it out today and stopped to get a bite. when i restarted the check engine light is on, also says service traction control and service active handling, and it runnung real rough. I was only two mile from home so i took it slow and parked it. I want to blow it up, i just bought it 9 days ago and now this is my secong problem. Any suggestions whats wrong or how to fix this
maybe some one can help me. I just bought a 2020 gs with 2,700 miles. i took it out today and stopped to get a bite. when i restarted the check engine light is on, also says service traction control and service active handling, and it runnung real rough. I was only two mile from home so i took it slow and parked it. I wont to blow it up, i just bought it 9 days ago and now this is my secong problem. Any suggestions whats wrong or how to fix this
Moderator
Received 3,570 Likes
Factory has a problem of connecting plug wires correctly.
And, because you have a problem you want to "blow it up", real mature attitude, what are you twelve?
It's called ranting. You're not in the OP's shoes. You've never ranted about anything? You know what they say about glass houses. Lighten up dude and move on to the next post.
The car certainly is not driven much. My money is on the fact that you probably need a new battery. As most all Corvette folks know when you have these types of problems it is usually a battery.
wouldnt really blow it up, just very upset by it and was trying to express how much, i love the car . as far as acting like twelve gfys, you have nothing nice or constructive to say, say nothing then
_"SCOTT"_
Sounds like you simply have a loose plug wire. Check to make sure they're seated on the coil packs and then on the plugs. It shouldn't take you more than 1-2 minutes.
Same thing happened to a friend in a 2010 GS yesterday, 5000 miles. One of the plugs wires came loose up under the FRC on the right side. He found another one next to it loose also.
This--->http://forums.corvetteforum.com/c6-c...-handling.html
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,427 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
A battery on its last leg will cause many of the symptoms you describe.
