steering wheel shake
hey,
just picked up a 2013 grand sport coup from kerbecks on friday. while driving it home i noticed that there was some steering wheel shake at around 70 mph. hase anyone experienced this problem.
thanks
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
New does NOT mean correctly aligned. Make sure the lug nuts are torqued down correctly, get an alignment, and check the tires for balance. One of those 3 is your culprit.
Elmer
Elmer
I have the same problem. It has been aligned and 3 times balanced (road force). My slight vibration now sits at 80mph.
Each time a balance was done, the vibration changed a bit and was observed at a different mph.
I had the same problem with my 05. I have aftermarket rims and no Tire pressure sensors. I have run flats and it is hard to tell if they are low in air by just looking at them. Well I checked them and they were all off by 10 to 20 PSI. This is something simple you can check if you haven’t. I pumped them up to 30 PSI, problem gone.
Might also be a bad/damaged tire.
Anyway, torque the lug nut to 100 ft-lb ASAP!
If that doesn't fix it, take it to a local dealer... doesn't matter if you bought it somewhere else, any Chevy dealer should fix it at no charge under warranty.
Although not a bad idea to set the alignment up for the way you are going to drive, it's likely not related to any vibes. I'm convinced that a certain amount of vibration even after tires are road force balanced and maybe even replaced if at the wide end of the range is possible. I think it is somewhat inherent in the stock Goodyear run flats as well as other low profile stiff sidewall tires. If a vehicle is sitting idle for some time, it seems to be more evident but lessens after driving a bit.
Received 1,500 Likes
Correct, I still have it. It is minimal, so I decided to live with it. Too many trips to the dealer and a messed up wheel. Although, they did warranty the wheel. But even after that, still couldn't get rid of the vibration.
I will try again once new tires are needed.
Add to the list of possible culprits brake rotors being out of round. With my two GS's both needed alignment and road force balancing of the tires, one needed a tire replaced that was out of round, and the other needed brake rotor replacement. If you have a good dealer, they'll eventually get it right -- it's warranty work and parts, and they want to make you happy.
