Why I am sometimes setting off my car alarm
Hi.. I have a 2012 GS convertible... I must admit that some elements of how the RKE and the locking/unlocking of the car have eluded me. Here's the scenario. I park the car, say at work, and when I leave I click the lock button twice (quickly) on the RKE. I hear the horn honk once as I'm supposed to and off I go... When I come back later I often want to get into the trunk first (convertible trunk). The RKE is in my pocket. I push the button above the license plate and the trunk opens... So far so good.. I then get finished in the trunk. To close my trunk I have to let it close most of the way and then I have to put both palms right above the latch mechanism and push down hard (that's the subject of another post I made some time back)... But anyway, sometimes when I do that, the car alarm goes off (horn honking one per second or so)... I grab for the RKE and hit a button to shut it off... Why does the car alarm go off in the first place?? The button under the trunk allows me to open the trunk so surely it sees the RKE and says it's ok to get in the trunk... I never have a problem there... It's then when I go to close the trunk (hard) that the alarm goes off... Do I need to use the RKE button to unlock the car before I do any of this or is just having the RKE in your pocket good enough??? So what's going on?? Any help would be much appreciated... thanks... bob...
Sounds weird.
Only possible thing I can see from the sequence you've given is hitting your FOB lock button twice may be the culprit. Why are you doing that? I've owned many Corvettes, never did it myself why I ask.
Considered using your 'Auto-Lock' feature? When I exit my Z doors automatically lock, sounding the horn once as confirmation. Opening doors with FOB in pocket, automatic. Same for accessing hatch, using FOB or button.
Take it to the dealer. Doesn't sound like normal behavior.
Possible the trunk latch is defective and sending the wrong open-closed signal, or maybe the BCM itself. Might be a code that a dealer can read thrown by an alarm.
Very simply explained. When you close the trunk the first time, it signals the computer that it is closed. Then when you go back and push it down a second time, the latch mechanism is intermittently reporting to the computer that the trunk is being opened mechanically (as if you were using the metal key). Any time that the car is locked and a door or trunk is opened by a non electronic means, the alarm will go off. This would include the emergency cable releases on the doors and the metal key release on the trunk. It would also include someone opening one of these with a crowbar. The presence of a fob outside the door or the trunk during one of these non electronic openings will not stop the alarm from going off because under these circumstances, the computer does not look for a fob. No electronic signal has been sent to the computer that would cause it to look for a fob. If your trunk latch is adjusted correctly, you should be able to give the lid a light push when it is open and have it drop to the fully closed position on the first try. A work around for you would be to simply unlock the car with the fob at some point before closing the trunk. You could even push the unlock button before you push the trunk button on the fob.
Sounds weird.
Regarding the lock button on the Fob, here is what the manual says,
"Press once to lock the doors. When LOCK is pressed twice,
the lights flash and the horn sounds to confirm locking."
In actual fact the lights also flash when you just click the LOCK button once but the manual doesn't say that, at least not in what I quoted above...
bob...
1 Post
#1 it shouldn't be so difficult to close your trunk.
#2 Your alarm definitely should not be going off in that scenario.
Unfortunately you're going to have to take it back to the dealer for warranty work.
