check engine lite P0449 ???
Old 09-16-2012, 10:42 AM
spice
spice's Avatar
Default check engine lite P0449 ???
hi
my check engine light came on a while back and just before it came on the dic said "check gas cap" . so i replaced gas cap. check engine lite still stayed on. after reading some posts about this i thought it might take a few start ups/refueling for it to go away. it hasn't.
anyway this morning i went to autozone just for the hell of it and had them read the codes. this what the print out says -
P0449
definition-
(evaporative emission system) purge/vent
soleniod circuit condition
explaination -
the sloeniods and system wiring are montiored for opens or shorts
probable cause-
purge or vent solenoids defective
check connector and wiring
fuel saturated vapor canister
failed EVAP vent solenoid
car runs and sounds fine. what gives? is it ok to drive?
thnks spice
Old 09-16-2012, 10:55 AM
gar4403
gar4403's Avatar
I recall that some have stated that gas cap related error requires multiple on/off cycles before the code will disappear. Or get a code reader to clear the error. Looks like the P0449 is not only the gas cap. Check out this previous thread for some good info:
http://forums.corvetteforum.com/c6-z...tepinside.html
Old 09-16-2012, 10:58 AM
TTZ06VETTE
TTZ06VETTE's Avatar
It's emission related so I would get the dealer to fix it.
Old 09-16-2012, 11:23 AM
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
You have to do what you feel is best but I'd clear the code (or have AutoZone clear it) and monitor the situation to see if the DFC returns. If the fault code returns I'd take the car to the dealership and have them diagnose the issue.
Long story short I once had the check gas cap warning. Someone suggested instead of trying to screw the gas cap down tight, I put the gas cap on as 'loosely' as possible. I mean the cap is on but I don't try to screw it down tight. I've never seen another check gas cap warning. In another instance, I once fueled my car from a 5-gallon container which had a hard plastic spout that required I press-down hard on it to open the fuel release valve. After using it my fuel gauge stopped working and I had some 'high-level fuel sensor' fault code. I continued to drive the car and in a month or so the gas guage stared working again and the fault code went away. Go figure.
Again, do what you think is right but I'd clear the code, drive the car and see if the code returns. If so, take the car to the shop. Good luck!
Old 09-16-2012, 12:12 PM
ADIBELC6
ADIBELC6's Avatar
vent solenoid right hand tank top
Old 09-16-2012, 12:34 PM
SolidlyStated
SolidlyStated's Avatar
C7 of Year Finalist (stock) 2019
I got that code for loose gas cap. Cleared the code at AutoZone and it never came back.
Old 09-16-2012, 05:24 PM
spice
spice's Avatar
thanks fo the replys. i asked them at autozone to clear the code but they said they couldn't do - by law. i will just get my local mechanic buddy to do it and if it returns just take it to a dealer. as i said car runs and sounds perfect.
the new electric stuff is nice - when its working- but i really don't see the need for some of it. lol
Old 09-24-2012, 12:07 PM
Street Rat
Street Rat's Avatar
I just got this code on my wife's 2008. My tuner cleared it but it came back. The gas cap looks fine. We dropped it off at the dealer this morning. We have never taken the car to the dealer for anything yet. I sure hope they know what they are doing.
Old 09-29-2012, 06:29 AM
spice
spice's Avatar
street rat . how did you make out at the dealership ? what did they find?
thnks spice
Old 09-29-2012, 07:02 AM
MikeyTX
MikeyTX's Avatar
Received 2,186 Likes on 1,337 Posts
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
thnks spice
There was a story in the Austin American Statesman this past week about one of the local chevy dealers accidentally sending a customers Corvette to the crusher. Wonder if it was his ...............................
Old 09-29-2012, 07:21 AM
JKbride
JKbride's Avatar
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
As I was reading this I was wondering if I started this thread and forgot because I have the same problem that started last week.
I purchased a new cap from my local dealer ($22 gulp) and he told me it should clear after about 50 miles, but it did not.
I have yet to refuel and have a code reader and will clear the code myself. If it comes back then I will take it to the dealer, bend over and ask them to be gentle
Old 09-29-2012, 08:05 AM
Street Rat
Street Rat's Avatar
The problem was the fuel tank vent solenoid. The part was $26.06 and it needs an upgraded harness to go with it. The harness costs another $37.30. I got jammed for $243.88 total.
From what I've read the part is easy to install. So if your car is out of warranty you may want to do it yourself. This is my wife's car and she made the decision to go ahead with the dealer install.
I think the part should be under the emission warranty. I'm in the process of finding out why it wasn't.
My dealer experience wasn't a bad one at all. I asked that the car not be washed. It wasn't. It came back with no body damage due to improper lifting. I was contacted three times during the day with updates while it was in the shop. It was fixed in a timely manner. The dealership that I used was Don Hewlett Chevrolet in Georgetown, TX.
Old 09-29-2012, 09:22 AM
JKbride
JKbride's Avatar
Street Rat thanks for the info. I'm pretty handily with a wrench so may just do it myself if its easy to get to without a lift.
Glad you got it fixed
Hey, Spice...how's yours progressing? Keep us posted......this seems to be common problem.
Old 09-29-2012, 10:25 AM
spice
spice's Avatar
hey street rat thnks for the timely reply. its seems that this is a common problem and a easy fix. thnks
jk, i have done some research and it seems like the fuel vent solenoid is the problem. it may also be the fuses but most likely the solenoid. i like u am pretty mechanical so i will check it out. seems like a pretty easy diy project. i will keep updateing just dnt knw when as i am very busy and not in corvette mode . keep us posted on your work also
spice
Old 09-29-2012, 10:35 AM
johnodrake
Moderator
johnodrake's Avatar
Received 3,578 Likes on 1,619 Posts
Check the emissions warranty. Certian components are warranted for 8/80.
http://www.epa.gov/oms/consumer/warr95fs.txt
Old 10-08-2012, 07:51 AM
spice
spice's Avatar
had time to work on car this weekend so here is the update -
1st i thought i would buy a code reader. seems like a handy thing to have and i can use it on my truck. it's an actron - $126
next i cleared the code. started car up . the cel didn't come on . the directions in code reader say to start the car 2x as the it may take a couple of cycles to b sure. after a couple of start ups the cel came on so it's not the gas cap must be solenoid.
call autozone. they can get in a couple of days - $23 - with long weekend probably middle of next week i figure. call chevy dealer. they have solenoid - $35 - ouch and harness $37 so i bite bullet and get it as this is the only time i have to replace it
jack up rear end and put it on stands. looks easy enough. squeeze clip on hose with pliers, unplug solenoid, slide old solenoid off, slide new on, plug harness in done.
next clear codes and start up a couple of times. everything seems good no codes come on so i guess it's fixed. time will tell
not really a hard job just a pita. its kinda of hard to reach in and unclip harness and the solenoid slides off to the back of the car not the front - took me a couple of trys to figure this out lol
anyway i saved a few bucks which bought my code reader.
spice
Old 10-08-2012, 09:49 AM
Street Rat
Street Rat's Avatar
It's good to see that someone did this themselves. I'm glad you didn't get taken by the stealership like me.
To check engine lite P0449 ???
Old 10-08-2012, 10:11 AM
JKbride
JKbride's Avatar
Tnxs for the update. I have been out of town since I last posted and will reset codes and refuel today. If that don't work then I will purchase the parts from my local dealer and install myself.
Any pics? If not when I do mine ill do I DIY thread.
Old 10-08-2012, 12:55 PM
spice
spice's Avatar
no pictures. try buying the parts frm autozone or the like. it might be cheaper. it's pretty simple just get car up high enough and it will be easier. also the clips are trickey as which way they unclip at least for a novice. and remember the solenoid slides off towards back of car. safey glasses will help as to keep dirt ect from falling in eyes.
Old 10-08-2012, 12:58 PM
spice
spice's Avatar
thnks street rat. kinda a diy guy. hate to spend the money and like to see how things work
Quick Reply: check engine lite P0449 ???
