Help with a power seat problem!!!!
Hello I posted a while back about a problem I had with a power driver's seat on my car. I am still having problems and I am looking for any help PLEASE!!!!!
I have a 2007 base model Corvette with a LS2 and a 6 speed manual transmission. I have a power seat on the driver's side only and no side airbags.
A while back I was driving down the street and my seat moved backwards and down all on its own. It ran my battery dead so I replaced the battery and pulled the fuse. I talked to some local corvette owners and here was given some advice (thanks to everyone I do appreciate it). My seat had moved so far back and downwards that I can not get to the rear bolts to remove the seat.
So today I decided to end my problems and I put the fuse back in. Of course the seat does not move at all and I do not hear the seat motor at all. I tried to reset the drivers settings (for driver one and driver two) but nothing happens. I checked the fuse and it is not blown. So a friend of mine said to add power directly to the motor and move the seat forward......
I reached under the seat and unplugged a connector that looks like it goes to the motor. It has 3 red wires and 3 black wires. I started at one end and added power to the red wire and grounded the black wire and the seat raised on the front end of it tilting it back more. I then went to the middle wires and did the same thing and nothing happened. I then went to the 3 set and did the samething but nothing happened.
Now my seat is in a worse position and the car is even harder to drive. I do not want to take it to a dealer and get ripped off (it is out of warranty) but I am ready to take a torch to it. Please I would really appreciate any help on how to either get this seat out so I can work on it or how to even move the seat to a better position.
Hello I posted a while back about a problem I had with a power driver's seat on my car. I am still having problems ad I am looking for any help PLEASE!!!!!
Cool just so I understand, where I applied power to the red wire and grounded the black wire just switch the wires and the seat should move the other direction. I will do this tomorrow. THANKS!!!!
Be careful not to lose access to the front bolts because you moved the seat too far forward .
Thanks for the input. I was able to reverse the seat movement and the front is no longer tilted upward and I can drive my car again. I tried to reverse the polarity on the two other wires and I am not able to move the seat forward.
Is there any suggestions or wire schematics as to which wires I would jump to move the seat forward. I still want to be able to remove the seat in order to make it functional again. I am even thinking of replacing the seat with an upgrade. Thanks
Received 8,927 Likes
Check the attachment for various seat connector wiring diagrams. AAB stands for memory seats.
Bill
Bill
I just fixed one for a buddy, the main wires going to the memory module broke off at the connector! I was amazed, never seen that before. His was a 05. I was able to access the rear bolts with a universal swivel socket and 3' extention.
Mine had exactly the same problem. Wires broke off right at the two main power terminals and I had to repair it using standard slide on connectors since I didn't have access to a metra pack.
Received 2,051 Likes
St. Jude Donor '13
Sometimes, a dealer or independant shop familiar with Corvettes, is the best way to go.
Thanks for all of the input. The wiring schematics is awesome and I will use it this weekend. I did try to get back there with a swivel socket and will probably try again this weekend. I am hoping to fix it this weekend. Thanks to everyone!!!!
THANKS for everyones input. I used the wiring schematic and was finally able to move the seat forward and get to the rear bolts. I found out that the problem is that the wire connector will not stay connected to the switch on the side of the seat. I did not know how to remove the side panel and switch on the seat (no side airbags), so I just set the seat where I like it and that is cool. THANKS
