C6 Fog Light Question
Hi all, I just purchased the Corvettemods 6000k HID low beam and fog light kit. Looks great! One of my fog lights surprisingly has already gone out so I'm not sure if it's the connection or a defective bulb. If anyone has any ideas on that I'd love to hear them.
My main question though, is there a way to get the fog lights to turn on with the low beams? Every time my low beams turn on, I need to turn the fog lights on manually. Thanks!
Former Vendor
St. Jude Donor '12-'13
If you have the low beams on and turn on the fog lights they will stay on until you switch to the high beams but they will come back on automatically when you switch back to low beams. Are you saying that is not working? The fog lights will not just come on when you turn on the headlights. Just have to turn the fogs on that one time while you are driving, but must repeat that cycle each time the lights are turned off entirely.
Most likely, you have a bad ballast on the side that's out. Take the ballast from the bad side & plug it into the good side to see if the bulb ignites. If it doesn’t.....you have a bad ballast
Remember - touching HID bulbs is bad, M'Kay.
Bad balast
Yup. My first experience with Corvette mods had a bad balast. Along with switching the balast from one side to the other, you might want to check the voltage at the fog light connector. If you have too low voltage, the balast won't work correctly.
CV mods tech support was very helpful. Issue resolved.
corvettemods are great people.their lights are guarented.they will replace it free of charge.
Its' funny I have the same problem one of my fogs went out and just installed them a couple of months ago.
I would not have know if I had not noticed it in the reflection from the car in front of me. And no, when you turn on the fogs the lows do not come on. My lows are set on automatic.
Will have to check the connections. It's a pain. But I know CM stands behind the products they sell.
