Need some advice about brake dust.
Ok, I'm that guy that appreciates a clean car and enjoys the challenge of keeping mine that way. That said, the brake dust from my new 2013 GS with black rims is driving me nuts. I drive 25 miles and the rims are taking on a red tint, looks like I have driven down a clay road. Spoke with the dealer and he says that for the first 5000 miles it will dust quite a bit. Asked about switching to ceramic pads and was advised that it would cut down some. My question is, those that have switched to ceramic pads would you say it cut down, 50, 75, 100 percent, any? I've ordered the Pinnacle wheel cleaner and brush in hopes that it makes the cleaning easier. Have to roll the car forward while cleaning because of the lack of space between the caliber and rim, on the front. Also, I don't know what the factory uses, but did you use the one piece pads or go with the multiple pad setup? If you made the switch give me your input and no I don't have pictures. I can't stand looking at it enough to take pictures.
On my last 3 Corvettes, the first thing I did was go to Ceramic Pads. I know what you are talking about, the way the OEM pads discolor the wheels. The Ceramics do not get rid of all the dust but the Ceramic Pads will get rid of most of the dust. I do not race my car at all, just everyday driving. If you are going to race it, I will leave someone else to comment about Ceramics and racing. Congrats on the new car. I have had no problems with my Ceramic Pads at all. There is a spray that you can apply to your wheels and it will help the dust not sticking to your wheels. I think its an Armorall product. I just cant recall the name right now.
Sorry, should of added that, this car won't see the track. It's just for our weekend touring enjoyment. I've also read the searches about waxing the rim and plan on doing that to aid in the cleaning. Just thought I would seek some first hand experience about he issue. Thanks for your input.
1 Post
St. Jude Donor '12-'13-14
+1 on ceramic pads. Now the wheels get only as dirty as fast as the rest of the car. And no more squealing.
I went with Carbotech 1 piece pads. Also with Carbotech you can switch out to a race pad if you want to go racing and not have to worry about cleaning up the rotors as the pad material is compatible.
GS brake dust is a way of life,I don't complain about it I clean it. Every time I drive my car it gets wiped down with detail spray along with the wheels. Cleaning the barrels every couple weeks I use Simple Green and a long handle brush....spray with hose,brush,rinse then blow dry with leaf blower and wipe with micro fiber.
Before.....
After.....
Before.....
After.....
On my base coupe that I traded in of the GS, I never noticed the barrels. But seeing how dirty they get now really opened my eyes the difference being clean makes. Looks like ceramic is they way I need to go. Thanks again for your input.
Once again I can not more strongly recommend Porterfield R4S pads...extremely low dust, excellent bite and no squeal and since you are not tracking they are perfect for you use. I drive to events/gatherings and bar none everyone is amazed at the almost non existence of dust and if there is mainly stuff coming off the road. Really should consider Porterfield pads>>
http://www.porterfield-brakes.com
id say about 90%. I was in your boat pulling my hair out that the rims had to be wiped every time I drove it. Switched to posi quite's (sp?) and havent looked back. Best thing ive done to the car, now I can drive it several times before even seeing any brake dust. I got the pads off amazon, front and rear for around 240 shipped..........
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Agree with everything that has been said here. The dealer who says it will improve after 5000 miles is blowing brakedust up your a$$. It won't improve - at all. The pad material is the same throughout the pad - how would it improve? Ceramic pads ARE the way to go - I'd say they cut dust down 90+ percent for me. No squealing either. This isn't unique to Corvettes - BMW, Mercedes, Audi, etc. all have the dusting issue unless you change to ceramics. Easy change also - do it yourself.
gm makes ceramic pads that gets rid of most of the dust.if not change them with hawk ceramic pads.my 2012 gs has black wheels and after 20 miles they turned **** brown.tried armorall wheel protectent and nada.did not help.changed the pads at 2500 miles and much better.
Received 2,051 Likes
St. Jude Donor '13
On our Z51, using Rjex on the wheels allows the brake dust to be easily removed with just a touchless car wash, instead of scrubbing.
Any advantage going with the 1 piece pad over the 12 piece set up? And was really shocked at how many cleaning products are availble for wheel and tire care from Autogeek.
I have the same pads, (thanks previous owner) hardly any dust at all.
if you keep them waxed and hit them with detail spray from time to time, the dirt and brake dust will flow right off simply by washing with your favorite car wash soap. you don't really need all those products.
Some of the sites don't offer their pads in 2013 models. Are the 2012 pads the same for the 2013's? I don't recall reading or hearing about any changes between the model year. No more dumb questions and thanks again. The wealth of information is exactly what I was hoping for.
