Replacement LED Tail Light Sets @ JWM
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Update the dated look of the stock tails with our LED replacements.
** Tinted options available. See site for details. **
100% plug n play. 5 minute install on these.
Includes resistor pack on each tail to combat hyperflashing.
Yes these are the same lights big parts stores are selling for $350+
$304 for the set of 4
$11 shipping USA
Order your set here <----
Daylight
Pretty!
Show winners
Super bright!
Nothing like these in the day when off
$11 shipping USA
FREE Set of License Plate LEDS with each order!
Here is a comparison of stock vs our leds
$11 shipping USA
Daylight
Pretty!
Show winners
Super bright!
$11 shipping USA
Hello......Does installing these Replacement LED Tail Light Sets "STOP" the 3rd brake light from working? when you step on the pedal?......
I noticed that in ALL you're pictures "NONE" of the 3rd brake lights are lite on the cars with the brake pedal be pressed.
can't get through inspection without that 3rd high brake light working at the same time the brake lights are being pressed..
are there ANY pictures showing these Replacement LED Tail Light Sets with the brake lights on and the 3rd brake light?
thanks
thanks
thanks
thanks
It's just easier to take a photo with the lights on (Not the brake) if you're by yourself.
Banned Scam/Spammer
thanks
thanks
Randy (poster above) pretty much covered it.
Those pics are with the lights on (no brakes). With just the lights on the high mounted stop light doesn't light up.
Oh Ok...thanks for the quick respoce too...:-)....i'm having a real problem........here my thread....http://forums.corvetteforum.com/c6-c...post1582241875
Even if that is the case, neither of those could have caused the problem.
yes,........you are correct..........i installed lights last week and installed spoiler today........thought there might be a connection
but its true after unpluging the connector from the 3rd brake light and swiching over to the new spoiler.....pluging back in there is no more 3rd light....every other light works....and i did not need to tug on the connector either...it came righ off.....
thanks for you're responce
dealership says re program or flash BCM.......i'm totally lost.....:-(
So the center light was working after you installed the LED tail lights correct?
Looks like you may need the dealer to figure this one out.
Never heard of this problem happening before.
WOW..I've had 3 different guys take a look......and all 3 say the same things....
connector look like new--except NO Power
the wire looks perfect (no tuging,pulling,pinching or any signs or anything like that)
all three say, that this is something that "I DID NOT CAUSE".....there is no longer power comming to the 3rd brake light.....period
again........all fuses look fine.
ALL lights.......allway round the car work
everything inside the car works....
so at 12:00 yesterday the 3rd brake light was working.........
....at 12:30 yesterday...the 3rd brake light has NO POWER at the connector..........
somebody please tell me I'm dreaming......
thanks for everyone advice........seriously
One way to be sure is to try another 3rd brake light from someone with a C6 near you (if possible). That would definitively tell you whether its the brake light or the your wire connection.
