opening drain plug on 06 radiator
am going to service my 06 cooling system- what is the proceedure to drain coolant- how do you open the plug- are there any issues with it resealing properly?- how much new coolant should I add? - first time I have done this - has 7200 miles- never done a plastic radiator - also have 79 vette which is all brass which is easy - thanks in advance
Retired & lovin' it!
Draining only the radiator leaves a good % of the original coolant in the block & expansion tank. It's tough to flush the cooling system completely, but to be somewhat more thorough, you can drain the radiator; remove & drain the expansion tank; refill the system with distilled water (to prevent any minerals/chemicals in your water from attacking the radiator core); run the engine until full hot (thermostat open). Let it cool; drain the radiator & expansion tank again; add Dexcool & water to fill; run the engine again to hot; finally add whatever amount of distilled water is needed to bring coolant level full up. This is more work, but IMHO is more effective.
Extremely easy to do. Drain **** will open by hand. Just did this on my 07. Could not be easier. Takes forever to drain though due to large cooling capacity. Make sure you have a large pan to catch the coolant.
