Runflats just got me home
Well, it's what you always wonder about...when will the flat get me? Today it got me at work, and tonight I was the last one leaving at 1am. Got in the car and had a LEFT FRONT TIRE FLAT message greeting me. It occurred to me that this was the only vehicle I have that DOESN'T have a mini pump on board, gonna have to fix that. Had about a 9 mile ride home, did 45 the whole way. There weren't really any gas stations I felt great about stopping at at 1 in the morning, so I just drove on.
I'd never driven on a flat runflat before, and it was a little unnerving at first. It made the typical flat tire sound at low speed, just a buckling rubber sound is the best way to describe it. It pulled slightly to the left, but not a big deal. When I got home, I was surprised to feel how warm the tire was...almost hot, and this on a cool night, about 40 degrees. I know they say you can go 50 miles at 55 miles an hour, but I'm not sure I'd want to risk that. Had I had a pump on board, I could have pumped it up enough to get it home w/out the warning constantly popping up. Good news is I took a look in the garage, and it's just a small nail, just slightly bigger than a finishing nail, stuck right in the middle of the tread pattern, should be a easy fix for Mr Goodyear.
So there you go, they do indeed work
UPDATE:
http://forums.corvetteforum.com/1582330807-post30.html
UPDATE:
That's worth bragging about?
While the tire is designed to get you to a place to fix the tire, driving on it as you described is not good for the tire. The tire was hot because it didn't like what you did ....
Although I will add, I would not be without a small air compressor and plug kit in any car without a spare.
OP, please let us know if the tire is still repairable. When I had a nail in mine, the first thing they asked before they fixed it was "did you drive on it flat" I didn't, and didn't think to ask if it made a difference in repairing it.
what's the point of having runflats on the car if you can't drive on it?
as the OP said it was 1 am, and I would suspect the run flat is designed as stated by the OEM, to be driven carefully, slowly and briefly, which the OP did.
He felt comfortable driving through the hood with a flat, I would have stopped and put air in it, but that's me. Chances are the tire will be ruined, but then if you're bucks up, have at it. As for alternatives, leave it to the AM and grab a cab, call AAA, call a friend
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I didn't get any impression that the OP was 'bragging' about anything, just giving us his experience with the runflat tires. If a runflat tire can't make it 9 miles then what's the use of having them because I wouldn't consider that distance to be very far in retrospect to getting a flat and the nearest gas station.
Now I could be completely wrong and can't remember where this info came from so long ago.
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Thanks for posting your experience. I was also wondering how they would perform.
Not sure where the bragging is. glenb must be having a bad day.
Have done that twice in 8 years.
I have always understood that, yes, it was designed to be driven on, but that would ruin the tire, understand that before you drive on it. It's designed to get you to a safe place.
Have not had a front tire flat but the rear tire flat drove much nicer than I had expected. Just for the record, the tire was new when I had the flat.
Received 2,051 Likes
St. Jude Donor '13
Our 2009 Owner Manual said that if you drive less than 25 miles at less than 55 mph, the tire should be repairable if the original damage was not too bad.
Other brands may be different, Firestone says not to repair at all. But many shops just inspect the tire like they would a Goodyear, and repair if practical.
I believe the C5 runflats were good for 50 miles if flat, but they also beat the fillings out of your teeth when inflated.
Runflats do have their purpose. I was driving one day on the freeway and I ran something over. I felt it and next thing I knew, the low tire pressure light came on. I was doing about 75. I slowed down because I was worried but honestly the car felt fine. I drove about 5 miles to the nearest gas station to pump up the tire to see if it will hold air. No chance. There was a hole big enough to almost fit my finger through but the tire was still round. Didn’t even look like it was flat. I then got back in the car, used my GPS to find the closest tire place. About another 3 miles. Drove over and they patched it up.
I was really impressed on how well the runflats with literality no air in the tire. After that day, I seriously contemplated getting another set when the time came…but I eventually went away from the runflats. I figured after 8 years and only 1 flat, I would rather have a better tire for a better overall driving experience versus have a so-so tire that will help me in the off chance of another flat.
