If you and the passenger stick your arms out and go fast enough they might take off. I discovered plastic holders that pull out in the fender wells. Pulled back and was able to fix. Thanks for nomenclature lesson though.
Normally I'd try that although I read somewhere about 2 hands on the steering wheel and now there is confusion at the positions
BTW, they can also be pulled out gently to remove the whole assembly. The rears can be accessed through the outer tail light.
