Oil cap
Old 12-02-2012, 09:20 PM
c6tech
c6tech's Avatar
Default Oil cap
I bought a 2013 base coupe and the oil cap says dexros?Did GM and Mobil 1 have a falling out.Also what weight oil do you use 5w 30 ??.
Old 12-02-2012, 10:27 PM
ByByBMW
Support Corvetteforum!
ByByBMW's Avatar
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Not really a falling out. IIRC the manual still recommends Mobil 1 but it's not on the oil cap anymore. Also IIRC 5W-30 is the weight most folks use.
Dexos is a spec. GM came up with to make money and M1 meets that spec.
Old 12-02-2012, 11:11 PM
GrayC5
GrayC5's Avatar
As mentioned above, dexos is a spec. Some MY 2013s came with the dexos oil caps. Others like my 2013 Grand Sport dry sump with the familiar Mobil 1 oil cap.
From the 2013 Grand Sport coupe owner's manual:
Specification
Use and ask for licensed engine oils with the dexos1® approved certification mark. Engine oils meeting the requirements for the vehicle should have the dexos1 approved certification mark. This certification mark indicates that the oil has been approved to the dexos1 specification. Corvette recommends Mobil 1® engine oils that meet the requirements of the dexos1 specification for its dry-sump equipped engines.
Old 12-03-2012, 12:50 AM
96GS#007
96GS#007's Avatar
Received 1,743 Likes on 1,051 Posts
Old 12-03-2012, 09:04 AM
c6tech
c6tech's Avatar
Default Oil
I received eight free oil changes when i bought the car.i will ask what the dealer puts in.I will also check the oil at the auto parts to see if there is a Dexos rating on it.Thanks for all the responses.Also I am learning how to use the radio nav bluetooth stuff.my 67 camaro had a AM radio wonder if. i can still get one. How about 8 tracks and a upgrade of a fm converter.Just kidding we have come a long way.
Old 12-03-2012, 11:46 AM
Thrash
Thrash's Avatar
Yes ... and Yes ...
Old 12-04-2012, 02:55 PM
c6tech
c6tech's Avatar
Default Oil
I was at the local wal-mart today.The mobil 1 5w30 quart containers say dexos on the front.I found no other oil with a dexos rating.
Old 12-04-2012, 06:08 PM
Gearhead Jim
Gearhead Jim's Avatar
Received 2,051 Likes on 1,362 Posts
St. Jude Donor '13
Since "ordinary" Mobil1 5W-30 meets the Dexos1 spec, it's easy to meet both requirements.
BP09
Cruising
BP09's Avatar
Here's the list of Dexos1 approved oils:
http://www.gmdexos.com/licensedbrand...sedbrands.html
Wally World in my area carries M1, M1EP, PP and QSUD which are all full synthetics...you'll be fine with any of them.
Old 12-05-2012, 03:12 PM
c6tech
c6tech's Avatar
Default Oil List
Thank you for all the responses and the oil list.I will stick with the mobil 1.
Old 12-05-2012, 03:24 PM
Jimmy W1
Jimmy W1's Avatar
I noticed this on an oil cap in the showroom last week on a 2013. I'm still sticking with Mobil 1 also.
To Oil cap
Quick Reply: Oil cap
