Hard water drip
Old 12-05-2012, 12:15 PM
speedraider
speedraider's Avatar
The OP has stated that he doesn't have access to an outlet. So, after washing the car and drying it, slide a paper towel under the mirror its self and it will pull any water that is in there.
Old 12-05-2012, 12:19 PM
Don-Vette
Don-Vette's Avatar
Originally Posted by speedraider
vinegar and water
Yep, that's what I use on water spots.
Old 12-05-2012, 12:34 PM
johan gouws
johan gouws's Avatar
Originally Posted by BWF07
The problem with the mirrors, is they hold a lot of water. If you don't have access to an outlet, I would order a set of the mirror covers so you don't continue to have this problem. until you get the covers, you can buy a 3 pack set of the compressed air in the can at Office Depot or any place like that. Use them to blow out the excess water. After that take some paper towels and slide them up in and around the mirrors to soak up the remaining water.
Just cover with used plastic bag from your last supermarket run. Keep it simple!
Old 12-05-2012, 01:07 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Before I spray any water on my car, I wrap the door mirrors with saran wrap. After I wash the car, I remove the plastic wrap, and clean the mirriors without spraying any water on them.
Got rid of the dripping water for me.
Old 12-05-2012, 01:24 PM
Jimmy W1
Jimmy W1's Avatar
I have hardwater, too. I take it to a car wash, spray wash it, drive it home and let the wind (a short spurt at about 80 mph) blow it off. (Most car washs around here really soften their water.) Then, when I get home, I towel dry the rest. The damp towel takes the water spots off. Any bugs get removed with McGuirers cleaner wax. I keep enough McGuirer's Carnauba on it to keep the water spots off and keep it from being scratched. It works for me.
Old 12-05-2012, 02:14 PM
cpmatthew
cpmatthew's Avatar
There are a few ways to prevent the water spots, and most have been mentioned. Your questions is how to get rid of them now that they are there. I would think any good car polish and foam applicator would clear it up. Depending on the polish, it may remove any wax you have, so you will need to wax that area again. Vinegar and water will also remove wax.
Old 12-05-2012, 03:14 PM
MTsVette
MTsVette's Avatar
Location: O'Fallon Illinois - Currently own a 2016 Z06 1LZ A8 Coupe
Get a leaf blower or some of device that uses the high pressure air and it will get the water out of the mirrors as well as other places that hold water, such as the tail lights.
MT
Old 12-05-2012, 07:24 PM
Thesisinbold
Thesisinbold's Avatar
Vinegar and water worked like a charm. thanks!
Old 12-05-2012, 07:28 PM
bud miller
bud miller's Avatar
Originally Posted by CBRXX
There are cordless leaf blowers.
ditto..and i would not use scratch x..too harsh for the clear coat...or just drive home from the "touchless " car wash and do at least 65mph..
Old 12-05-2012, 09:27 PM
hawkgfr
hawkgfr's Avatar
Received 1,212 Likes on 824 Posts
You learn over time which places to be carefull with direct spray...side mirrors and tail lights...shoot those quickly and at an angle where you don't just load them up with water...they will drip for hours if you don't learn the trick..
Quick Reply: Hard water drip
