Cheap NPP control?
Old 12-11-2012, 10:48 PM
Sayfoo
Sayfoo's Avatar
Default Cheap NPP control?
I'm getting ready to install a used set of NPP mufflers on my base '08, and I'm thinking about a cheap/easy way to control them.
Basicall, I need a vacuum hose from the engine to the mufflers, and some way to open/close the hose. Right??
I'm looking for some kind of manually operated open/closed, inline switch. Something like the push/pull or rotating switches used to control windshield wipers on old 30's-40's cars and trucks.
Obviously, I'd like to get something small that could be mounted under the dash or in the consol, that wouldn't be real obvious.
Another option would be a 12v solenoid and a rocker or push button switch. This would be a little more involved, but still simple.
Any thoughts on what parts would work?
Old 12-11-2012, 11:28 PM
trenchgun
trenchgun's Avatar
This looks interesting...
http://forums.corvetteforum.com/c6-c...-in-a-box.html
Old 12-12-2012, 05:56 AM
NevadaVette
NevadaVette's Avatar
Sunset Orange Creations has a variety of products to contol your exhaust any way that you want, including retrofit kits:
http://www.shop.sunsetorangecreation...4?categoryId=5
They are a very helpful and reliable vendor and specialize in NPP type systems.
Old 12-12-2012, 09:35 AM
haljensen
Support Corvetteforum!
haljensen's Avatar
Cheap and easy? Run the vacuum hose to where you can reach it from the drivers seat and use vise grips to pinch the hose when you want loud exhaust.
Old 12-12-2012, 01:33 PM
Thrash
Thrash's Avatar
All I needed for mine was a large push-button and an Add-A-Circuit. Put it on the dead pedal and works like a charm ...
Old 12-12-2012, 02:43 PM
Top_Fuel
Top_Fuel's Avatar
But your car was equipped from the factory with NPP exhaust, right?
I think the OP is looking for a cheaper alternative to something like NPP-in-a-Box...
A few people have saved a few dollars by engineering their own vacuum control box, so you may want to search for those threads.
My best advice to the OP is to start the NPP installation by tapping the vacuum source on the back of the intake first. If you can manage to do that successfully, it's all downhill from there.
Old 12-12-2012, 03:19 PM
Flh Den
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
Flh Den's Avatar
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Originally Posted by trenchgun
Gregg, Because your option codes in the glove box and the vin check we did both show NPP on your car, my bet is that for some reason the original owner changed it to a stock muffler system. Why he did that is anyones guess, but if he didn't like the noise he would have just left them in the stock position and they would have been quiet 99%of the time. He could have sold them as they do have some value and replaced them with a stock set that he had or took in trade. That would make more sense. Before you buy this kit get it on a lift and look for vacuum lines and a manifold tap for the vacuum lines. I'll bet they are there. At that point you can decide what system you really want and shop from there.
Denny
Old 12-12-2012, 07:53 PM
Sayfoo
Sayfoo's Avatar
OK wise guy
This IS the basic plan, but I will use some kind of a air switch or electrical switch/solenoid combo to make it a little more convieniant.
Looking here for hardware recomendations.
Old 12-12-2012, 08:30 PM
L82Brake
L82Brake's Avatar
I considered MacGyvering my own vacuum solenoid too. After waisting a lot of time on it I just ordered the NPP in a box. It has the T, tubing, directions etc.
Good luck with it. All you need is the solenoid the NPP in a box has and switch it with 12 vdc. The remotes are a gimmick. I could do without them.
To Cheap NPP control?
Quick Reply: Cheap NPP control?
