Telescoping steering wheel
Old 01-07-2013, 10:40 PM
Move Over
Move Over's Avatar
Default Telescoping steering wheel
Just landed my 2010 GS on Thanksgiving and one thing I noticed is that the telescopic steering wheel adjustment on steerng column does not function. Yet, the seating control memory setting adjust the sterring wheel just fine.
I presume it's just a bad switch and not a fuse since the memory settings work fine. Anyone had a similar issue?
Old 01-07-2013, 11:02 PM
ChevyDave
Support Corvetteforum!
ChevyDave's Avatar
there is a fuse shown in the 2010 GS manual, in passenger kick panel, for... TELE
SWTCH/MSM
and yes, from my guess it is also for seat memory. but wouldnt hurt to check it.
oh.... try this, see post #2.. http://forums.corvetteforum.com/c5-g...wont-move.html
and post #9... http://forums.corvetteforum.com/c6-c...heel-quit.html
i read that there is (3?) connections under driver seat and if one not connected good, will cause loss of telescoping <--my bet is on this
Old 01-08-2013, 08:50 AM
calemasters
calemasters's Avatar
When I replaced my memory module, I had to use the Tech 2 to program the telescopic steering column. If the motor, switch, module, wiring, etc. are all OK, maybe try reprogramming.
Old 01-08-2013, 09:39 AM
ChevyDave
ChevyDave's Avatar
f.y.i.
the telescoping column switch is item #3 here.. http://store.gmpartshouse.com/parts/...agramCallOut=3
and is GM parts number of 88963397
Old 01-09-2013, 05:27 PM
Move Over
Move Over's Avatar
Thank you for the infomration, gents. Looks like I will have some garage time this evening after work :-)
Old 01-09-2013, 09:45 PM
Move Over
Move Over's Avatar
Well, no such luck. Memory settings will extend or retreat the column but not the switch on the steering column itself. Looks like dealership material.
Old 01-10-2013, 01:26 AM
CO Lightfoot
CO Lightfoot's Avatar
Originally Posted by ChevyDave
...i read that there is (3?) connections under driver seat and if one not connected good, will cause loss of telescoping...
If there are also problems with seat functions, then I agree it might be underseat wiring or something else: http://forums.corvetteforum.com/c6-c...t-no-work.html
If the seat works fine, then I think the OP is right -- sounds like a bad switch on the steering column.
To Telescoping steering wheel
Quick Reply: Telescoping steering wheel
