Why does my car smell like rotten eggs after i get on it?
I have a '12 coupe 6m with 13k miles that i bought new and have always used high test top tier gas, SHELL, SUNOCO etc,,. For about the last 6k miles anytime i let er rip it really stinks for about 5 seconds after than goes away. It never used to do that. any ideas? Car runs fine. MPG'S have never changed.
I have a '12 coupe 6m with 13k miles that i bought new and have always used high test top tier gas, SHELL, SUNOCO etc,,. For about the last 6k miles anytime i let er rip it really stinks for about 5 seconds after that than goes away. It never used to do that. any ideas? Car runs fine. MPG'S have never changed.
Change your diapers before you nail the pedal.
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
There's sulfur in fuel additives; your engine isn't burning it completely and your catalytic converter is storing it and then releasing it as hydrogen sulfide when you add load to the engine and force more air through.
Try switching gas stations. Sometimes an engine misfiring or out of tune might cause this as well, but not likely given the age and mileage..
I know DAN thats why i always use top tier gas to avoid any build up that might occur with a cheaper brand gas if thats at all possible. would a bottle of TECHRON do anything but as you said DAN the car is fairly young, it would be hard to imagine a build up of anything this early in the game on pretty good gas.
I just found this post on a Lexus forum, same complaint as you had.
"Just to confirm, I had my car checked out at the dealer and the mechanic told me due to certain brand of gasoline have more sulfur. That will create the foul smell and it's normal under hard acceleration".
The smell you are smelling is hydrogen sulfide (H2S). It results from using fuel with high sulfur content. (Much of the fuel sold in the US contains a LOT of sulfur -- much more than is legal in Europe, for example, though the Govt. has mandated a reduction to Euro sulfur levels in Diesel fuel over the next several years). You can sometimes reduce or eliminate this problem by changing brands. That is often not a permanent cure since refineries usually buy from a variety of suppliers and the amount of sulfur in any one brand varies as a result.
Simplify
Location: forging ahead...making up for lost time and embracing each day thankful to be alive.... nj
~~~ CFOT Book Folder ~~~
Received 1,497 Likes
it is the sulphur in the gas like some others have stated, if you remember your chemistry from school then you'll know that H2S smells like rotten eggs
As mentioned by flhden above, it's quite likely the gasoline you're buying contains a higher sulfur content than most others. All gasoline contains some amount of sulfur. In addition to the smell, the sulfur, especially in gasoline with higher sulfur content, can also foul a car's fuel gauge sweep/sending unit, causing it to not work properly.
Try some other gasoline stations in your area, preferably/hopefully ones that get their supply from a different fuel jobber (wholesale marketer). Each jobber can supply gasoline to any number of different branded stations as well as unbranded independent stations. It's likely that the gasoline with higher sulfur content may be coming from one or just a few and not all the jobbers that supply gasoline stations in your area.
Good luck!
Good luck!
