Side markers
Old 02-21-2013, 10:33 AM
petiebear
petiebear's Avatar
Default Side markers
How do you remove rear side markers ???
Thanks in advance.
Old 02-21-2013, 10:37 AM
ChevyDave
Support Corvetteforum!
ChevyDave's Avatar
You need to remove the outer tail light.
One screw in the top and the tail light falls right out.
Then you can reach in and get to the side marker light.
If you are just replacing the bulb, the socket/bulb just twists out.
If you are removing the entire assembly, there are two tabs that you squeeze, then the side marker pops out.
Old 02-21-2013, 10:38 AM
ChevyDave
ChevyDave's Avatar
oh...........
When you reach in, make sure you don't knock off the clip that your tail light screws into. Sometimes these are loose and will slide right off.
If you do lose it, it's a common little part that you can get at Autozone/etc.
Old 02-21-2013, 10:52 AM
petiebear
petiebear's Avatar
Originally Posted by ChevyDave
oh...........
Thanks ChevyDave
Old 02-21-2013, 10:55 AM
MikeyTX
MikeyTX's Avatar
Received 2,186 Likes on 1,337 Posts
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by petiebear
Thanks ChevyDave
Also, be careful squeezing the plastic tabs on the markers. They brake easy. Ask how I know ........
Old 02-21-2013, 11:12 AM
petiebear
petiebear's Avatar
I will be replacing the stock ones with blackouts.
Thanks for the tip.
To Side markers
Quick Reply: Side markers
