What is the best way to remove oxidation
Old 03-09-2013, 09:53 PM
ButchN
Support Corvetteforum!
ButchN's Avatar
Default What is the best way to remove oxidation
I have a portable garage & left the hood closed, but not latched the 1st time I used my battery tender.
I mention portable garage because as you know, it is not moisture free like a real enclosed garage.
I noticed this week that slight oxidation has set in, or on my alternator bracket & alternator.
Is there some spray that I can use that 'eats' away the oxidation?
Car is only 5 months old so it's not crusty & set in.
Old 03-09-2013, 11:28 PM
switchblade six
switchblade six's Avatar
scrub with white vinegar and rinse...did mine last spring...this time im gonna paint em
Old 03-10-2013, 04:52 AM
Don-Vette
Don-Vette's Avatar
Old 03-10-2013, 01:56 PM
Gearhead Jim
Gearhead Jim's Avatar
Received 2,051 Likes on 1,362 Posts
St. Jude Donor '13
I think you'll want to be really careful about getting anything inside the alternator.
Ours has 4 yrs/55k miles and is not nearly that bad, but I leave it alone because I'm afraid of damaging the insides of the alternator. There's probably a safe way to do this, but I haven't researched it yet.
We've been using the CTEK tender that plugs into the cig lighter, for about a year. No additional corrosion in that time.
Old 03-10-2013, 02:15 PM
flange
flange's Avatar
St. Jude Donor '14
Get an old sponge, cut it into little pieces. Stuff the little pieces in the vent holes of the alternator, and use one of the ideas above. The idea of the sponge is keeping the products off the copper winding of the alt so you don't damage the varnish.
Old 03-11-2013, 05:50 PM
ButchN
ButchN's Avatar
I'l try these suggestions this week, thanks.
To What is the best way to remove oxidation
Quick Reply: What is the best way to remove oxidation
