A6 question
A6 question
I have noticed as the temps have been in the high 80-90's here in AZ that my trans temp gets into 180-190 range. This is far higher then all winter (was 160 ish) and it seems that when the car does 2-3 and 3-4 upshifts it sometimes revs a few RPM, maybe 150 or so. Have noticed this in a few other gear shifts but nothing as freaquent or noticable as those gears. Is this something to do with the higher temps? Or is my tranny starting to fail?
Still new to this car, around 7k miles for me and almost all highway (37of my 40 mile daily commute) so thought I should ask if normal or not before I take it to dealer, its a bit of a drive into town and the worst roads ever!
My car is an 06' with just under 50k, I do have the extended GM warranty but hoping its just a normal issue with higher trans temps.
Thanks for any input,
Jason
Jason
The fluid should be changed at 50K.
It won't hurt to swap out the old and install a new filter.
You will immediately notice a change in the shifting... However, this may not correct your problem.
Received 2,887 Likes
Seems to be the dreaded 6L80 shift flare. I have it sometimes too. There's a TSB for leaky O rings but I think I'll take my chances vs having a dealer tech disassemble my transmission.
Temps are normal
Temps are normal
It's never flared in S mode at the track, seems to do it when I am paddle shifting sometimes. Just annoying but I think ill take my chances seeing as I haven't heard of any failed transmissions due to it, rather then letting some dealer lackey take the trans apart.
Jason, like everyone is telling you above, the 6L80E transmission that we have has the tendency of flaring after some wear on it. First, it starts off as small 100-200 rpm spikes between 2nd and 3rd, 3-4, and even 4-5. 1st to 2nd gear will stay good, as will 5-6. The best thing you can do is go to a reputable transmission shop, or even a GM dealership, and have them flush out the transmission fluid and replace the filter. They'll be able to replace approximately 6 quarts out of the 10-13 quart total. This will help, especially if you are close to stock HP numbers, and it only costs approximately 100-200 dollars, tops. At this point, if you're still unhappy with the way the car shifts, you can have a local tuner that understands these cars tune your TCM (transmission control module) to increase line pressures and that'll definitely firm up your shift points! Don't sweat it, it really isn't that big of a deal. As far as your tranny temps go, they're just fine.
Received 2,051 Likes
St. Jude Donor '13
2006 A6 for 44k miles (sold)
2009 A6 for 56k miles, still driving.
No flare in either car, the 2009 seems to occasionally have a little "negative flare" when using the paddles at part throttle- like TC actually cuts back the power just a fraction TOO soon when doing a 2-3 paddle upshift. So the rpm drops slightly instead of flaring slightly. Not a big deal, and not frequent, but confusing when many others have flare.
Please make note, I had a similar problem that was resolved!
Please note. I had a similar problem on my 06 C6 A6 F55 NAV. Here is what was found and defintely a problem with shifting. I took it to one of the two most recognized Corvette tuning shops in the DFW area. One of the top representative drove my car for a differential problem, then he mentioned, out of the blue, that the A6 trans shifted funny. Guess what, the next time I was in a dealer and was allowed back in the shop, we checked the transmission. It was over filled from the assembly plant and we drained alot of "bubbly" fluid out of it. It was definitely overfilled and we went with the procedure of the car on the rack in the air and going through different gears, drive, sport, and reverse while the engine was running per GM directives. Did the bubbles flow out of that transmission, drained it until there was a slight flow of fluid so the bubbles could dissipate. Shifting problem solved. The bubbles in the transmission valve body definitely affected the shifting performance of the car. This ought to get your attention now.
Thanks everyone for the good info, glad to hear its a pretty common issue...I can definatly deal with it, just didn't want to be missing any signs. Again thanks, will have the vette guys in Phoenix do a flush!
Jason
