It’s not the Harmonic Balance...$800 later
It’s not the Harmonic Balance...$800 later.
This is a continuation from an earlier post
http://forums.corvetteforum.com/c6-c...sure-what.html
I posted about a noise my 2005 Corvette makes. Based on my information we all assumed it was the Harmonic Balance. Took car to corvette repair shop and they also stated it was the Harmonic Balance. Therefore the following was changed:
a) Harmonic Balance (shop)
b) Idler tensioner (me)
c) 2 belts (me) first set
d) 2 belts (shop) second set, yes…belts changed twice in less than 30-days
The sound I keep hearing has not changed. It’s the same noise before any repairs and after all the repairs listed above. Recap: 2005 Corvette with 88K miles. I hear a weird squeal at 2K to 2.5K rpm in 1st, 2nd, 3rd, 4th, 5th gear. If I maintain the engine rpms in the range listed above, the weird squeal sound remains the same. If I depress the clutch pedal, (disengage the clutch from engine) and maintain the rpms listed above, the sound goes away. If I take my foot off the clutch pedal (let engine connect to transmission) while maintaining the rpm listed above, the sound comes back. If I raise the rpms pass 3K the noise goes away. If the noise was related to the fan belts, pulleys, AC compressor, etc, the noise would always follow the rpms of the engine. The clutch position will have no effect. The noise is only present while car is in gear with the rpms between 2.5k to 3k.
I returned to shop and we test drove the vehicle. The guy said the sound is normal to corvettes. It’s something to do with the throw-out bearing. I want to make sure it’s not a hidden problem which a small amount of money today will prevent a large amount of money spend tomorrow. Have anyone heard a similar complaint or sound (earlier post), or how can I verify this sound is normal.
Sound: Weird squeal, squirrelee, small-vibrating, very hard to label this sound.
Went in with a squeal…..$800 harmonic Balance, $450 Radiator cage/support frame….$1,250 later Came out with new stuff and the same squeal…..priceless
hey reg, i hope you get this worked out, i know it can be annoying, but it may help someone recognize the problem if you take a vid of the sound. Maybe it's a clutch issue or trans issue since it goes away when engaged.... good luck
Received 2,890 Likes
I bet it is the diff. Mine does the same thing. I have heard it is a crap shoot to change it out. Might help but just as likely to not help.
Read where one cf member went through 3 to find a quiet one. Even then it might start squealing later. I just live with it.
mine is most noticable when diff is under a load but just barely. Like when trying to maintain a constant speed...30 or 75 for example.
Here is an earlier post from me regarding the diff.
http://forums.corvetteforum.com/c6-c...need-help.html
I will try to make a recording later today.
I did change the diff fluids about 3 weeks ago just in case. Here is a question...If it's in the diff the problem should be speed related. My problem is linked to the engine rpms at any speed. As long as the clutch is enagaged to the engine.
My shop said it was the diff pinion gear and not to worry about it. Most do it but it is more noticeable in a Vette cause you sit so close to it.
Sound goes away when load is removed from diff. and increases with engine rpm till it gets drowned out.
When you you were testing with the clutch engaged and disengaged were the back tires off the ground so they could turn with the clutch out and transmission in gear.
If that was the case, then the squeal could be coming from the torque tube bearings (3 of them), transmission or diff.
If the car was on the ground, and the transmission was in neutral, my pick would be a bearing in the torque tube.
I have a 2005, and at about 120-130,000 miles one of these bearings was completely shot (nosiy and vibrating).
I just fixed a squeek/noise underneath my car. Just want to point this out in case its something simple like it was in my case -
http://forums.corvetteforum.com/c6-c...imple-fix.html
I listened again to detect the noise. Enclosed is a quick recording of the sound. This time it’s not as loud as before. I cut a small sound bite from the actual recording and looped it to capture the chirping sound. It’s more like a bird chirping sound. I can also feel the sound by holding the gear shift ****.
All my testing has been on the street/highway. The rear tires are always in contact with the street.
Listen very closely and you can hear the chirping sound. Most of the time it’s much louder. I will try again after work for a better recording. Tell me if you can hear it.
One day last year I started up my 2006, and I noticed a chirp.
Like a squeaky belt.
Uh oh.
It only got worse.
I thought for sure it was my HB.
So, had a local speed shop replace it.
$700 later, I drive it out and the noise hasn't changed!
WTF?!
I immediately drove back.
Took the tech for a ride.
He said it's an exhaust leak.
My aftermarket headers were leaking.
The paper gasket had degraded, and the squeaking was caused by the same thing as blowing through a blade of grass held between your fingers.
They quickly replaced the gasket on the side that was leaking.
I asked about the other side, and they said it was fine.
Well...
only a few months later I heard the same sound.
The other side had given out.
Uh oh.
It only got worse.
WTF?!
Well...
Uh oh.
It only got worse.
WTF?!
Well...
Uh oh.
It only got worse.
WTF?!
Well...
simple solution,trade the car for a new 1.
I have had a noise from sometime that is both rpm and clutch engagement sensitive. It is not a squeal or squeak though. Traced it to the throw out bearing. Mostly noticeable when car completely warmed up and present in any gear. Goes away with disengagement. Had for a year with no real change in noise level so I just turn up the tunes and open the exhaust up.
Wait, so you have an 8 year old Chevy with 88K miles and you get the sound of a small bird chirping when the clutch is engaged and it only happens within a 500 RPM range? And this surprises you? Simple fix...Turn up the stereo J/K
I guess I'm too old as I remember Chevy's would basically fall apart after about 65k miles. 88k with only a chirp? Yea, thinking I would not lose any sleep over that.
What really sucks is having shops replace parts that are not needed. Did you mention that you thought it was the balancer? Just wondering how they would even suspect that as it probably was not bad.
Seriously, I hope you find your issue.
