Curb Alert Issue
Curb Alert Issue
I posted this issue to southerncarparts on their Curb Alert thread but the issue has returned.
http://forums.corvetteforum.com/1583592428-post19.html
Same as before, after washing my C6 the curb alert starts acting funny. I just finished washing my C6 and was about to pull back into the garage. Without even moving it beeped as if there was a curb. I got out thinking maybe I forgot my bucket in front of the car. Nope, complete clear. So I pulled into the garage, turned the car off and waited 10 minutes. Making sure there as nothing in front of the sensor, I turned the car back on and BEEP BEEP BEEP!
Turned car off, pointed the sensor level to the ground just in case it is "seeing" the floor. Only thing in front of the sensor now is the wall which is at least 5 feet away. I turned the car back on and BEEP BEEP BEEP!
Tried to re-calibrate and no joy. It constantly thinks something is in front of the sensor. If it is anything like last time, this issue may clear itself in a day or 2 but this is a PITA. I can't be the only person having this problem after a wash or did I just get a defective sensor and water is getting into the sensor somehow.
FYI: Since installing the curb alert, I have washed my car 2 times and both times I have had issues with curb alert.
Thoughts?
Thoughts?
I haven't had a problem with mine after a wash. If you can't get a warranty replacement, I'd try sealing the sensor module seams to see if that helps before buying a new one.
I will have to check on the warranty thing since it was a gift. I personally don't have a receipt for it.
I was thinking the same thing too. Maybe putting a bead of silicone around any of the seams in the sensor housing.
Well I called it. Curb Alert is working fine again. No phantom beeps or anything. I will give it one more wash and if it happens again that will be 3 for 3. Then I will hit up Southern Car Parts for a warranty replacement for the sensor or just seal the sensor in some way.
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Did you try to re calibrate it? I am guess you may of knocked it out of Calibration.
Use the method in this video below and shoot me a PM and let me know.
Jim
Jim
is the phantom beep a continuous beeping, or just one time. You know the curb alert beeps three times when it first gets turned on right? I have no problems with mine so far.....
After giving it a day to "dry" I went out and did the calibration again. Worked perfectly. Took me under a minute to calibrate the sensor.
While driving I would get the beep sound as if I was coming up to a curb. Road was perfectly flat, wasn’t going in/out of a driveway or anything. I only went for a 4 mile day and it went off roughly every 30 seconds. However, 2 days later I drove the corvette again and everything was fine.
Same as before, after washing my C6 the curb alert starts acting funny. I just finished washing my C6 and was about to pull back into the garage. Without even moving it beeped as if there was a curb. I got out thinking maybe I forgot my bucket in front of the car. Nope, complete clear. So I pulled into the garage, turned the car off and waited 10 minutes. Makh ing sure there as nothing in front of the sensor, I turned the car back on and BEEP BEEP BEEP!
Turned car off, pointed the sensor level to the ground just in case it is "seeing" the floor. Only thing in front of 9the sensor now is the wall which is at least 5 feet away. I turned the car back on and BEEP BEEP BEEP!
Thoughts?
Thoughts?
Thoughts?
Thoughts?
Homer- it sounds like the sensor may not tightened securely. If it has moved (rotated) during washing Please make sure the sensor is calibrated to the right curb height and tightened securely. If it still has the same issue after that, you could apply black silicone rubber on the sensor and on the sensor cable going into the housing (take care not to apply any silicne rubber on the lens. Your Curb Alert is warranted for 12 mo. Suggest you ask your vendor for a new sensor if the issue persists.
I had a similar problem with the random beeping that was due to the ground being loose. Try checking the connections and make sure your ground is held in tight. If it is loose, it will cause the beeping
This is a quick update on the issue. I washed my GS Saturday but before getting it wet, I wrapped the sensor in plastic and a rubber band. I did my wash like I normally do.
After I was done, I removed the plastic and Curb Alert worked without any issues. No recalibration needed. No phantom beeps. No issues at all. So the problem with the sensor acting up it directly related to the fact the sensor is getting wet.
Now I just have to decide it if is worth getting a replacement sensor or just deal with the one I have. Wrapping it in plastic wasn't too hard but I might just put a bead of silicone around all the seams and see if that helps.
I don't want this to come out wrong, so it's not meant to be mean or bust *****, but why on earth would you go through all the trouble of silicone or wrapping it every time you wash when it is FREE to get a new one under warranty. It's usually no questions asked and it's in the mail and then you never have to worry again. You spent $160 for an item that is broken, get it replaced and be done with it....
I have the same problem too.
I wash my car and the sensor acts up.
They sente a replacement module first but after reading this I think it's probably the sensor. I will now seek a new one.
Thanks for the post.
Agreed but since it was a gift I don't have the original receipt so was entertaining other options to resolve my issue. But no worries here. The company the produces the Curb Alert had followed my thread and has offered me a replacement sensor. Awesome customer service right there!
