Question for those with Duralast batteries......
The negative post on my Duralast battery seems to be slightly less diameter than the positive post. When I tighten the oem cable clamp as tight as it will go, it will still turn on the post when the cable is turned. I think this may be a problem with car not starting ocassionally and sending strange messages on the DIC. BTW, I have installed COH's column lock bypass. Anyone else notice smaller negative battery post?
Did that, but still won't tighten to a point where it doesn't turn on post. Thanks for responses everyone. Guess I have a terminal problem, not a battery post problem.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
also make sure you didn't lose the cone-shaped nut for tightening the cables. without it, you'll be tightening a loose cable.
