Caliper Painting/Z51 Brake Conversion
Old 04-21-2013, 05:43 PM
42Chevy
It's 5 o'clock Somewhere
Support Corvetteforum!
42Chevy's Avatar
St Jude Donor '13-'14-'15
Default Caliper Painting/Z51 Brake Conversion
I accomplished two things with this project. The first was to make the silver calipers compliment my car and not look like an eye sore. For this I used the basic G2 red caliper paint kit. The second was too upgrade from the base brakes to the Z51 setup. For this step you will need GM Z51 caliper brackets and Z51 rotors. The GM Z51 caliper bracket part #'s are 88964167 & 88964166. The rotors are available from several of the forum vendors or GM has them as well. I finished the project today and I could not ask for better results. I will try and give a complete layout with several pictures and all the tools you will need to do this project yourself.
First the tools I used. Everything is shown below that you will need except for the obvious, a jack and lug wrench.
Lets take a look at what I started with.
Here are my new brackets and rotors side by side so you can really see the difference.
Front:
Rear:
Follow the direction in the paint kit. I did not use the brush that came with the G2 kit. Instead I went to Sherwin Williams and picked up a good quality 1" brush. First remove the brake caliper. Next the bracket. Then the rotor. Next step is to clean all the dirt and grease from everything you intend to paint. Next, as you can see in the following pictures I held the caliper bracket and painted it first. Dont get to heavy or the paint will run. It will not look like its covering all that well with the first coat, but the second coat will look great. If you do get a run, use your brush dry and just work it out. I held the calipers in my hand starting with it upside down then rested it on the top of my spindle to finish the top side. After painting the bracket I used the top bolt to hold it to dry. Start with one coat and move to the next wheel doing the same thing. Work your way around the car and by the time you get all 4 done, it will be time to start the second coat. You will find the second coat covers much better, but again dont go too thick. You can always come around for a third "touch up" coat. After painting it needs to cure for 24 hours.
If you are doing the Z51 swap, you now need to clean and paint your rotors. For this I used two cans of brake clean for the four rotors. You have got to get the packing out of the fins or they will smoke and smell like crap the first time they get hot. Spray and clean them real well. Next I used basic black spray bomb caliper paint on the rotors. It is ok to get some on the face, in fact the back ones will need to painted or they will rust in the area the pads dont touch. Mine looked like this when I got done.
Now your done for day one. 24 hours later its time to reinstall everything. A thin coat of grease on your cailper slide pins is a good idea. Install everything the oposite of how you took it apart. Once you have all the brakes together, pump the pedal till it firms up. I was told to keep the paint off my letters i needed to use chapstick, but I chose not to because I was worried I would get too much on and create bad spaots around the lettering. Instead after I pumped the brake up, I took emory cloth to the letters being carefull to only rub the lettering. Here is the result.
This is how mine turned out after driving it home.
Overall I would say it made a huge difference and I could not be happier with how everything turned out.
Old 04-21-2013, 05:55 PM
Mad*Max
Mad*Max's Avatar
Received 1,500 Likes on 817 Posts
nice job!
Old 04-21-2013, 06:03 PM
EVRose
EVRose's Avatar
Looks great! Good job. Those rear rotors really do look small in that before shot.
Old 04-21-2013, 06:10 PM
GotVett?
GotVett?'s Avatar
Very nice job and looks 1st class. Tks for posting.
Old 04-21-2013, 06:15 PM
Dudeurgettnavette
Dudeurgettnavette's Avatar
Great write up
Old 04-21-2013, 06:18 PM
m kraz
m kraz's Avatar
very nice i like the gs style rims
Old 04-21-2013, 07:19 PM
spdkilz911
spdkilz911's Avatar
Looks great. Did you cover the "CORVETTE" lettering or just work around it?
Old 04-21-2013, 07:26 PM
42Chevy
42Chevy's Avatar
I was told to keep the paint off my letters i needed to use chapstick, but I chose not to because I was worried I would get too much on and create bad spots around the lettering. Instead after I pumped the brake up, I took emory cloth to the letters being carefull to only rub the lettering.
Old 04-21-2013, 07:34 PM
FlyerVette
FlyerVette's Avatar
Wow 42Chevy, looks great and terrific job with you pictures and explanation....!!
Old 04-21-2013, 07:38 PM
Yellow C-6
Yellow C-6's Avatar
2015 C6 of Year Finalist
They look very nice.....
Derwin
cmonkey713
cmonkey713's Avatar
Received 1,251 Likes on 916 Posts
They look great and the best part you did it yourself!
Old 04-21-2013, 07:41 PM
vig1116
vig1116's Avatar
wow, great job. So the calipers are the same as the stock base calipers, just the brackets and rotors are different?
Old 04-21-2013, 07:43 PM
42Chevy
42Chevy's Avatar
That is correct.
Old 04-21-2013, 07:44 PM
vig1116
vig1116's Avatar
Originally Posted by 42Chevy
That is correct.
nice! looks great!!
Old 04-22-2013, 09:10 PM
spdkilz911
spdkilz911's Avatar
Thanks.
Old 04-25-2013, 11:31 PM
42Chevy
42Chevy's Avatar
Thanks for the compliments! If anyone has any questions on any of this, feel free to pm me.
Old 04-26-2013, 01:16 AM
brooklync5
brooklync5's Avatar
Good work I did the same with the help of of buddy a while back. So nice to get your hands dirty instead of paying someone to powder coat them. Looks the same and you save a pretty penny.
To Caliper Painting/Z51 Brake Conversion
Old 04-26-2013, 02:04 PM
JFKLS3
JFKLS3's Avatar
You did a fine job. That makes a huge difference. Looks fantastic now.
Old 05-09-2013, 02:38 AM
hwhiteco
hwhiteco's Avatar
2015 C6 of the Year Finalist
Default Nice Job
Fantastic job...excellent pictures & tutorial...thanks for posting!
Just wondering...will eventually be looking for floor jack, stands and/or ramp set-up for my C6...any recommendations?
Old 05-09-2013, 03:37 AM
Indy-V
Indy-V's Avatar
What grit emory cloth did you use?
Quick Reply: Caliper Painting/Z51 Brake Conversion
