"I wait for my oil temp to reach XXX before going full throttle...."
Old 04-26-2013, 06:39 PM
///DarkSide\\\
///DarkSide\\\'s Avatar
St. Jude Donor '12-'13-'14-'16-'17-'18-'19-'20-'21-'22-'23-'24
180* is when oil is warm enough for WOT, if WOT is prudent.
REMEMBER - give time to the trans & diff to warm up as well. They also need heat.
Old 04-26-2013, 07:08 PM
TripleAstyle123
TripleAstyle123's Avatar
I wait until I have 180F oil temp. Oil Viscosity changes with temperature, that's why I wait.
Old 04-26-2013, 09:25 PM
Tonylmiller
Tonylmiller's Avatar
With Mobil 1 5W-30, I don't think it is a huge deal. But I also wait, at least until the water warms up. I feel that it is more of a thermal expansion issue than a motor oil viscosity issue, since the oil behaves like a lower weight oil when cold.
Old 04-26-2013, 10:35 PM
TulsaVette
TulsaVette's Avatar
I usually wait until I get out of the neighborhood.
Old 04-26-2013, 10:41 PM
VET4LES
VET4LES's Avatar
The Nascar guys warm it to 160 before starting the pace laps. By the time the race starts I'm sure they are around 210 or more.
Old 04-26-2013, 10:42 PM
maurouen
4th Gear
maurouen's Avatar
Not my taste but looks well done.
Old 04-26-2013, 11:02 PM
CodyC6
CodyC6's Avatar
Me too. But since my house is the first in the neighborhood I may not wait as long as others.
Old 04-26-2013, 11:08 PM
berk4422
berk4422's Avatar
167 - I heard that pilots don't use full throttle until 167. Also, it is just over the half way temp on my HUD.
Old 04-26-2013, 11:13 PM
pmartjr
pmartjr's Avatar
The problem with cold oil is the viscosity is much higher than normal and you will notice the oil PRESSURE is much higher than normal. The higher pressure builds up because the higher viscosity oil will not flow through the oil journals as it should for proper lubrication. Running the engine hard under that circumstance could be starving essential rotating parts of the engine and cause undue wear. If you will look at both the oil pressure reading and the oil temperature reading, you will find a number where the oil pressure finally reaches your normal pressure readings. At that point your oil temperature reading will be your "good to go" temperature reading. When that occurs, the engine can be used to it's full abilities with all the proper locations receiving the designed oil pressure.
Old 04-26-2013, 11:17 PM
arrie
Simplify
Support Corvetteforum!
arrie's Avatar
Location: forging ahead...making up for lost time and embracing each day thankful to be alive.... nj
St. Jude Donor '13-'14-'15
~~~ CFOT Book Folder ~~~
Originally Posted by vig1116
i stomp on it as soon as i start it to get it to warm up quicker, then once it's warm they say it's ok to stomp on it....
Old 04-26-2013, 11:22 PM
wannabe1
wannabe1's Avatar
I wait until I shift it from reverse to 1st after I am done backing out of my driveway. Then WOT down the street I go.
Old 04-26-2013, 11:32 PM
ExRedRacer
ExRedRacer's Avatar
Received 1,029 Likes on 549 Posts
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Bought my Vette from a retired pilot who knows a thing or two about WOT and said he waited until 150 degrees before getting on it and that's what I do....
Old 04-27-2013, 02:37 AM
  #33
Mr. Peabody
Mr. Peabody's Avatar
C4 of Year Finalist (appearance mods) 2019
I've always felt that If you’re able to drive a corvette every day of the week practically year round .... then you can afford the luxury of 15 minutes or more of normal driving to let the oil get up to 190 before you get on it.
In some small way letting it warm up to a higher temp will allow it to go to 150 - 250K and more more reliably before needing a major rebuild. Even when driven .... briskly.
I admit it rarely goes below 30 here all winter but if it’s -10 below and it will take you 45 minutes or more to warm up the engine not to mention the tires…. why would you want to stomp on it anyway?
Old 04-27-2013, 02:39 AM
  #34
ProfessorDeath
ProfessorDeath's Avatar
About 180 is pretty safe.
Old 04-27-2013, 11:07 AM
  #35
05blkbeauty
05blkbeauty's Avatar
How can you own a Corvette and never use wide-open throttle- at least for a few seconds?
Old 04-27-2013, 11:26 AM
  #36
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
I was standing next to a real C6R(18" away) and the car had been sitting for some 3 hours. Even before that, it had only been moved from the transporter. The engine was at ambient temp of 85 degrees.
The guy got in, started the car, and immediately started blipping the throttle to 5-6000 RPM. The engine didn't blow up.
My ears were ringing for several days after that, as I was standing next to the exhaust outlet.
Old 04-27-2013, 11:31 AM
  #37
michaelinmech
michaelinmech's Avatar
I don't have XXX's - I have little numbers on my oil temp gauge
To "I wait for my oil temp to reach XXX before going full throttle...."
Old 04-27-2013, 11:40 AM
  #38
JoesC5
JoesC5's Avatar
Originally Posted by PittMD1
I don't ever go WOT. I won't take the rpm's past 2500 until it is at operating temp 185 - 200.
There was another post where someone said it takes 15 - 20 minutes of normal driving to reach 165. You must be talking when the air temp is -20. It only takes me about 5 minutes just putting through the burbs and she is ready to go.
You live in AZ and I live in MO. There are far more areas in the US that has weather like in Missouri, then like in Arizona. The last cruise for lunch I made in my Z06 was a couple of weeks ago. Drove 40 miles at 40-65 MPH with some slowing down for traffic( one hour drive time). Ambient was 50 degrees and my oil temp got up to 136 degrees. Shut off the car for 30 minutes and then started it and drove 70 miles at speeds of 45-65(1.5 hours drive time). Ambient was now at 70 degrees and my oil temp was now at 145 degrees. Then hit heavy traffic for 10 miles, driving at 30-45 MPH and sitting at 3 or 4 traffic lights(30 minutes drive time).. When I reached the restaurant, I had to wait, idling, for some 4-5 minutes for the traffic light to allow me to make a left turn. Ambient was now 71 degrees and my oil temp was at 156 degrees. Total drive time of 3 hours to get my oil temp up to 156 degrees..
The only way I can get my oil temp up to 180 degrees with a 70 degree ambient, is to drive in first gear at 5000 RPM for 10 minutes.
I don't do that.
Driving hard(WOT) at Talladega with 90-95 degree ambient, I only see the oil temp hit 200 degrees.
Old 04-27-2013, 11:47 AM
  #39
JoesC5
JoesC5's Avatar
looks like you didn't check off the RPO box that allows you to show the oil temp in XXX. But, it is a very expensive option.
Old 04-27-2013, 11:55 AM
  #40
philip_g
philip_g's Avatar
a block or two
Quick Reply: "I wait for my oil temp to reach XXX before going full throttle...."
