removing wheel weights
I am looking at replacing the tires on my C6 next week.
Before bringing the vehicle to the dealership, I would like to remove the wheel weights and clean the rims.
Any suggestions on how to get the sticky weights off without damaging the rim surfaces?
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
soak them with goo gone or carb cleaner in a spray can. Use the little tube that should be tapped to the can. That will soften the glue. Then use dental floss under the weights. This is going to be a pita with the wheels on the car unless you have a lift.
Removing the weight shouldn't be a problem. A paint prep - Silicon/Wax remover will remove the glue. Should be interesting how your car's tires will jump around on your trip to the tire store.
wrap a butter knife in electrical tape. but presoak the weights simple green windex etc
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Try 3M adhesive after knocking off the weights.
