Black exhuast tips
Black exhuast tips
I am getting tired of polishing the exhaust tips after every track day. Polishing the outer 2 is fast enough but the inner 2 usually require some steel wool and take 3-4 times longer. I have see the Billy Boat black tips but I suspect an aftermarket tip without the holes inside would change the sound enough that I'd just rather do the polishing. So:
1. does the exhaust note change with these type of tips?
2. are there any black tips with a similar hole pattern?
Thanks.
Thanks.
Tips CAN change the sound, but I can't tell you how much with that switch.
Polishing tips shouldn't take as long as you're saying though. Once polished they should clean back up with minimal effort. What are you using? My tips only take me 3-5 minutes now to polish up once I got them to a nice, polished state.
Try putting a sealant on your tips...something easy like a spray wax. Should make your life MUCH easier.
you should not have that hard a time cleaning them.
use something like Mother's mag. wheel cleaner and the sutt will come right off while they are warm, if not a couple of swipes of a rag with the cleaner and they should come clean. I run a rag on them and the car every time it goes in & out of the garage & I don't even run cats
It takes about 20 minutes of scrubbing with 0000 steel wool to get the inner 2 to look like the outer 2 after a track day. The sealants I have used seem to have no real effect.
I started with Blue Magic, a polish and sealant in one. They polished up nice but needed serious elbow grease to bring them back. Then I tried some Mothers polish followed by Rejex. Let that cure for ~18 hours. Stuff is outstanding on the paint but didn't hold up any better than the BM. This why I am looking for tips.
It does when you have to wait a day or 2 to get to them. Will try what you suggest though after the last session of the day. Already get abused in the paddock for using detail spray to get rid of the streaks of rubber off the paint for the same reason - it's much harder a day or so later.
I have only wiped the outsides maybe 10 times and maybe 30 seconds total time to wipe all 4 tips. Never have to clean the insides...NEVER.
750 HP ZR1 makes a lot of heat and these still look perfect.
Think I am doing this, I've given up cleaning mine to only have them black 10 miles down the road. With no cats its a losing battle.
Received 2,887 Likes
[QUOTE=Grand Sport 13';1583857944]I hated cleaning mine too.....plus it was the only chrome on my Vette. I scuffed the tips and shot them with BBQ grill paint. I love the look!
They do look good.
Did you take them off to paint or just cover everything against overspray?
They do look good.
[QUOTE=Racer;1583859470]This is my second season with my tips Plasti-dipped.
Did the exhaust sound change materially after covering the holes in the tips with the plastidip?
[QUOTE=TKOGTO;1583862921]I did not take the tips off....just taped everything off and shot about three coats. I Preferred the look of the flat black, but the other post with satin looked pretty sweet!
[QUOTE=Grand Sport 13';1583866070]Was there any exhaust note change from the paint in the holes?
