This is normal engine temps, LS2
Just to tame down the people all the time worrying about engine temps, this is what it should look like when you drive normally. (LS2 engine Z51, no dry sump, 4.5L 5w30 Mobile1 filled)
On a highway or low traffic road in 0C (32F) to 20C (68F) temperatures:
Coolant temp: 90C (194F)
Engine Oil Temp: 100C (212F)
If you push your car harder, or drive in traffic, temps easily rise accordingly until you let it cool or drive like above again:
Coolant temp: 100C (212F) to 105C (221F)
Engine Oil Temp: 110C (230F)
If you're at the track, I don't remember what the temps are, but I'll be at the track in 2 weeks and update then.
It's easy to go above those temps by a few degrees, so stop worrying about your coolant temps being at 220F, it's normal.
Simple mistake!
In fact, GM per the instruction manual recommends to run ONE additional quart of oil over full when racing, helps compensate for "G" forces. I had a buddy of mine burn an Calliway engine up for not doing this on Xcrossing. He learned the hard way. He has had numerious Vettes and should have known better, he had two Calliways at the time.
I still like the 160 stat and have raced cars all my life and cooler temps are never a bad thing so I will stick with my 160 stat.
At the track i go way above those temps on the last round to take the win,hot laping seems to be the rule at our drag strip.
They are based on what my car displays for temperatures. Coolant temperatures are normal anywhere from 80C to slightly above boiling point. Oil temperatures are normal from about the same, but can go higher than coolant temperatures. The temps listed are what I read, but not necessarily the exact numbers that mean normal. Use as a guide, not absolute.
Sure, you can run cooler and have 6 qts. I put the quantity as a reference for my measures. I also run cooler many times, but that's when I don't drive very far. If I'm driving 3-4 hours, the temps stay pretty constant, that's makes it easy to know you have a problem.
Even if I had 8L of oil in my car (if I could), I'm confident it would hover between 95C and 105C. It has more capacity to cool because of volume, or rather, more capacity to absorb heat so you don't overheat. So it would take longer and more work to get the temps to climb or go higher.
Under normal circumstances, when cruising down the road (with the associated air flow) your "normal" temperature is regulated by your thermostat. Therefore, coolant temperature will reflect thermostat temperature, within thermostat tolerances; unless you are working the engine so hard that you exceed the cooling capacity of your radiator. Therefore, if you want a cooler engine, put in a better (bigger) radiator - the only thing a 160 degree thermostat does is allow the system to "absorb" short lived increase in engine heat. It does not increase the cooling capability of the cooling system.
There is no such thing as a normal oil temperature because most cars don't have a oil cooler of adequate surface area to cool the oil enough to regulate the temperature. More volume of oil helps because each quart of oil spends more time in the pan (where in cools) and less time in the engine (where it heats). A pan that transfers heat well (aluminum) will also help.
They all have the right idea!
I see someone else also reads the warranty book
I find it odd that my coolant temp. (ls3,a6) will drop 4-8 degrees at cruising speed if I downshift one gear. I'm guessing it's due to the water circulating faster, or the engine is actually "bogging" somewhat at 60mph in 6th.
You're exactly right. I've noticed the same thing in my Z06 but never noticed it in my prior Corvettes; could be that I've always had my DIC in oil temp mode and not in coolant temp mode. It's not as obvious if you're looking at the gauge as opposed to the digital readout too.
On my '08 (LS3), at highway speeds, just cruising along, with outside temps in the 70's and 80's, my coolant temp runs between 203 and 205. A friend of mine with an '07 (LS2), told me that's right about where his coolant temp is just driving down the highway. I stopped at the local Chevy dealer (service dept) not too long ago, and discussed with them, and they said that the coolant temps I am seeing are well within the normal operating temp range.
Same old samo!
For example, I happened to know the service manager at the nations #1 Chevrolet dealership in Grapevine, TX. I brought my car in for a power seat problem, two control units were replaced and other attempts were tried and failed. I had four invoices that I was showing to the write up guy and he got the assistant shop manager involved and he didn't even know about the seat system period. In the mean time, the service mananger had sneaked up behind me while I was explaining the invoices. All of sudden I sensed someone was behind me, I turned around and said hello "Tim", the service manager. He tooked the invoices and looked at them all and said they would fix the seat. He had them replace the complete seat motor mechanism and contol units, the seat has worked great ever since. As usual, "delay, delay, and delay". It never ends!
With a centrifugal blower and nothing for additional cooling other than a 160 thermostat I run at 181-183 on the highway with the AC on lowest fan setting with ambient temps around 85.
