Air Dam Fasteners?
Air Dam Fasteners?
On the base C6 air dam, there is a hole where each of the side pieces connect to the center section of the air dam. What fasteners go in these holes? The dealer parts guy looked it up but we couldn't find a fastener listed.
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
Stu
P.S. I bought them at an auto parts store (can't remember which one), if you find that more convenient
You don't want to encounter the space-time continuum sans those pins - one minute you're on the way to the Home Depot and BLAMO, in an instant you're in the Drive Thru at Krispy Kreme . . . . . that's exactly why Chevrolet uses nothing but top notch plastic push pins for that critical application . . .
Thanks for all the input, humor included!
Thanks for the offer mad-axeman, I already had some laying around.
Wow, a cheap corvette part, who'd a thought....
Dorman could be OE, who knows...
Air Dam Fastners
Same subject just another part of the question. As noted in the thread there are several sizes. What size fits tying the three air dam pieces together? 1/4 5/16 3/8??
Doug
Doug
Received 2,047 Likes
St. Jude Donor '13
I had my air dam and side pieces replaced recently, and the GM parts book simply does not show those pins. I asked the tech, he knew what the "problem" was and said he just grabs a couple of the proper size from the parts bin.
GM probably did use these fasteners because they are cheap but they do act as break-away parts. I would much rather these pins came out easily rather then tear-up the air dam which is so low it scraps anything above 2 inchs high on my car.
