What defect makes the acid buildup on a battery?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,817 Likes
2015 C7 of the Year Finalist
I have had 2 incidents where the negative terminal on my battery (Optima Red top) have cause the dreaded system DIC messages. In both cases, the crud has built up on the negative terminal to where the DIC gets pissy and starts with the message barrage. The first activity resulted in me being stranded in Key West and having to use a tow truck.
This was my first episode,
TOP
BOTTOM
My 2nd episode happened to these terminals:
My first bout, I blamed on the cone shaped nut missing and that allowed a loose fit that resulted in the corrosion.
The 2nd bout was NOT due to anything getting loose. That clamp was tight as hell! It still did the corrosion build up to dick with my DIC.
The question is why? Can there be some kind of leak in the battery that is pushing up caustic fumes or acid itself to get the corrosion like this. I've NEVER had this issue on any other car that I've owned and maintained. It sucks to carry tools to get the terminal off and a wire brush to clean that crap off the connection.
I have a spray-can of that red stuff you use to seal the terminals to prevent the corrosion and I had to clean that stuff off as I cleaned out the corrosion. So, that didn't seem to alleviate the issue.
If a new battery would cure this, then that red top is toast!
Thoughts?
TOP
BOTTOM
Thoughts?
You may have an acid fume leak around the terminal. If you have ever hammered on the terminal, that can cause a leak. Doesn't have to be anything but a very, very small one to cause corrosion.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I think Euro is correct and some of it is a bit normal. Even the tightest of batts. will outgas. I know they're old fashioned, but those little green and red felt things do work, and so does all the prep before (baking soda, elect. grease, etc.). And sometimes it's just a slightly defective batt. itself.
Well, I'd like a smaller battery this time. Anyone have experience with Duralast?
http://www.autozone.com/autozone/par...6425_622393_0_
