Need torque specs. info.
I don't have the '05 C6 shop manuals. Does anyone know the torque specs. (ft/lbs) for the bolt that holds the rear control arms and the bolts that hold the rear sway bar bushings.
Had to remove these the get the LS7 catbacks in.
A quick search should have pointed you to this link, but here it is again.
http://forums.corvetteforum.com/auto...id-farmer.html
Forum member David Farmer has some great torque spec sheets you can print out, laminate, and throw into your tool chest.
He closed his website - but, he's still got his torque spec sheets in the cloud. If you can't get to those cloud links, go to his Facebook page.
Bob
Bob
