HUD not working
HUD not working
I have a 2007 that the cruise control didn't work on. I got great advice to unhook the battery and that fixed the problem, but now my HUD doesn't work. Looked in the manual for a fuse, but it doesn't show which one it is. Any suggestions?
Are you using a different fob? IIRC, the memory features (3LT option group) can tie the HUD brightness & position to a specific fob.
Anyway, try the HUD controls.
First get max brightness (+). The try the up/down adjustment.
Just to clarify, your HUD was working and now it doesn't work? By "not working" do you mean that the display is blank? Did it happen suddenly or gradually? Do any of the HUD controls do anything? Can you see it moving when you press up/down and look into it? Can you see the "ring" around the edges? As much info as possible might help.
I'm using the factory key fob and I've tried using the HUD controls with no luck.
You might get lucky and have the right-size SPARE in the passenger-footwell fuse box.
Edit... See pgs 420 - 426 in the online owner's manual: http://www.gmpartshouse.com/download...07corvette.pdf
Former Vendor
if cluster lights are working the HUD fuse is fine. To check fuse look under passenger side footwell for Fuse.
