From my Owners Manual ...
Just doing a little browsing of my '07 Owners Manual ...
High-Speed Operation CAUTION:
Driving at high speeds, 100 mph (160 km/h) or higher, puts an additional strain on tires. Sustained high-speed driving causes excessive heat build up and can cause sudden tire failure. You could have a crash and you or others could be killed. Some high-speed rated tires require inflation pressure adjustment for high speed operation. When speed limits and road conditions are such that a vehicle can be driven at high speeds, make sure the tires are rated for high speed operation, in excellent condition, and set to the correct cold tire inflation pressure for the vehicle load.
If you will be driving your vehicle at speeds of 175 mph (282 km/h) or higher, where it is legal , blah, blah, blah ...
This is marketing genius (though stuck into an Owners Manual) ... not quite to the Viagra 4 hour warning, but not bad ....
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I'm surprised someone reads the manual.
I increased my tire pressure from 30 psi cold to 32 psi cold when I did my laps around Talladega Superspeedway. I figured it would help to have the pressure a little higher. I guess my average speed was close to 100 mph, and up to 152 mph on the back straight. But it was only 5 laps at a time, with temps in the 80's.
1 Post
I'm not sure you shouldn't adjust the air pressure lower??? With the heat and speed, tire pressure increases...could it get too high? I'm asking cause I don't know.
St. Jude Donor '10-'11-'12-'13-'14-'15-'16
I stayed at 30 psi cold and did 4 sets of 5 laps at Talladega ... top speed 158. broke 150 many times. rock solid exiting turn 2 between 125 and 130. (2010 coupe)
Received 8,928 Likes
http://www.tirerack.com/tires/tirete....jsp?techid=72
As you can see it can get complicated.
Bill
1 Post
You forgot to mention the tires should be pumped up to 37 psi if maintaining speeds of 175 mph
It's in my Warranty book!
Miller Time Wisconsin 🍺
Location: The only thing we have to beer is beer itself 🍺
Received 1,440 Likes
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
My tires were at 32 psi when I got to Talladega but never thought to check them after my runs. I got over 150 mph numerous times with no issues.
I personaly counted well over 150 Vettes at the track and I did not see anyone bleeding or adding air to their tires. I also didn't hear of anyone having any tire problems or flats, and most everyone hit triple digits...with alot of guys hitting a buck fifty+.
