Race ramps for a GS - size question
Plan on buying a set of 2 piece race ramps and the Xtenders to use mainly with my 2013 GS.
Does it make any difference if I buy the 56 or 67 inch ramps?
Former Vendor
Reverse Logic offers three Race Ramps models with a two-stage incline that will work with your GS. Basically, the ramps have integrated XTenders. They are available in 72", 80" and 87" lengths and the heights of the platforms are 8", 9" and 10" respectively.
The RLL-80-2 80" model has an invertible incline section which can be used as a trailer ramp.
Many CF members have purchased the two-stage incline ramps and you can find several reviews on the forums.
We have been offering a 10% Store-Wide discount on orders of $200 or more for the last couple of months. You can also get a $20 Cash Back factory rebate on these custom two-stage ramps through 30-Jun-2013.
Fred,
Thanks for the tips. With your 87 inch length you can easily drive up a GS with no body parts scraping?
If that's the case I'll cancel my Amazon order and order from you guys.
PS: Bummer, tried to cancel the Amazon order and was unable to. Thanks for the advice regardless.
Former Vendor
Neither the front lip nor the air dam on the GS will scrape with the 6.8 degree incline sections on the 87" ramps. The price is about the same as the combination of the RR-XT-2 and RR-EX-14. But with the 87" ramps you can get an optional trailer ramp adapter to convert the incline section to a trailer ramp.
You may also want to check out the slightly less expensive RLL-80-2 ramps which have a cradle top platform and the invertible incline section.
Fred,
