Patch a run flat? pics
Old 07-13-2013, 09:33 PM
mfj427
mfj427's Avatar
Default Patch a run flat? pics
can these Michilins be patched? Crap!!!!!
by luck we where already home when i heard it.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 07-13-2013, 09:48 PM
CaryBob
Support Corvetteforum!
CaryBob's Avatar
If you bought the road hazard warranty, get it replaced. I've done it with three RF tires. If not, get a tire place to try to patch it from the inside. Don't just stuff a plug from the outside.
Old 07-13-2013, 09:49 PM
Firewater Burns
Firewater Burns's Avatar
I had my GY Supercar runflats patched in a similar area and it has worked fine for 3000+ miles.
Old 07-13-2013, 09:57 PM
mfj427
mfj427's Avatar
thanks!
Bubbling pretty good @ 40psi
[IMG][/IMG]
Old 07-13-2013, 10:12 PM
BettermostCorvette
BettermostCorvette's Avatar
Yes but you should pull it off the rim and do a patch from the inside to assure the tires speed rating.
Old 07-13-2013, 10:15 PM
mfj427
mfj427's Avatar
right, will do. thanks friends!
Old 07-14-2013, 11:49 AM
MikeMaj82
MikeMaj82's Avatar
I had a screw bigger than that not too long ago in my rear tire. Had it plugged at a gas station for $10. Not worried about speed ratings because I never go over 70.
Old 07-14-2013, 12:09 PM
dcarter0001
dcarter0001's Avatar
Nice garage
Old 07-14-2013, 05:36 PM
LS WON
LS WON's Avatar
Originally Posted by mfj427
thanks!
[IMG][/IMG]
I did this very same thing using Dyna Plug and drove another 6 months before I replaced a 4 tires with new ones.
Old 07-14-2013, 09:02 PM
Woodstoc
Woodstoc's Avatar
Over 140000 miles on my C5' quite a few sets of run flats, and picked up my share of screws. While Discount Tire would always fix them for free due to the business I did with them, many times I would save the hour or two at the tire store and plug them myself from the outside. Never had any problems with them. I think I patched about 10 or so over the sets of tires. I wouldn't patch a sidewall issue however.
To Patch a run flat? pics
Quick Reply: Patch a run flat? pics
