Something so simple... yet
Old 07-13-2013, 11:43 PM
J Christensen
J Christensen's Avatar
Default Something so simple... yet
In the process of adding a backup camera system, something so simple as removing the rear view mirror... have all the mods done and now I am having a heck of a time getting it back on.
Taking off: twist/turn and off it comes.
So far twist/turn is not putting it back on. My muscles fail me.
Does anyone have some relatively sure fire method to get this thing back on?
Thank you.
Old 07-14-2013, 12:06 AM
budgreen3564
Support Corvetteforum!
budgreen3564's Avatar
No. I took mine to a local garage and they snapped it right on quickly.
Old 07-14-2013, 01:35 PM
C6Whatever
C6Whatever's Avatar
Lisa
Old 07-15-2013, 01:20 AM
J Christensen
Anyone with a DIY type solution/idea?
Old 07-15-2013, 01:32 AM
Dif
Dif's Avatar
Sounds like you're doing it right, but did a Google search and found this ..
when putting it back on, place it at the angle it was at when it came off and twist on without pushing too much.
Check this ..
http://forums.corvetteforum.com/c6-t...-a-2006-a.html
And this ..
http://forums.corvetteforum.com/c6-c...-off-help.html
Hope this helps
Old 07-15-2013, 05:48 AM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
Thank you.
Probably need to turn/twist instead of twist/turn to put it back on ....
Couldn't resist.
Actually, I have no idea. I didn't even know you could take it off easily.
Old 07-15-2013, 02:02 PM
J Christensen
Dif,
Yes, thanks. I've tried that but I guess I just don't have the touch or the muscle push to get it to insert. It does have to go at a 45 to horizontal then push and turn horizontal.
It at the dealership today for an oil change, high speed buzz happening again, and a look at the brake fluid issue needing to be replenished now as it has gone a tad just below half, sending the service alert. They'er going to put it back on.
I was almost considering using a soft rubber clamp but decided not to risk the windshield.
Old 07-15-2013, 08:19 PM
J Christensen
Well, the dealership got it up in no time and no charge. Very nice.
Old 07-16-2013, 12:18 AM
Dif
Dif's Avatar
To Something so simple... yet
Quick Reply: Something so simple... yet
