Miles vs age
Old 07-20-2013, 01:50 PM
  #41
ButWhatDoIKnow
ButWhatDoIKnow's Avatar
Check out cars.com or autotrader.com
These will give you a good idea of what are fair asking prices. Look at both dealers and private sales.
Old 07-20-2013, 04:59 PM
  #42
hdkeno
hdkeno's Avatar
Both cars overpriced imho. I just picked up a mint loaded 3lt 06 with 7500 miles for just under 31K. But i also got 20k for my 2000 c5 with 50k...
Old 07-21-2013, 12:02 AM
  #43
bobc5
bobc5's Avatar
Both cars are over priced, look for a 2008 or 2009 with less than 20,000
Miles. Search all the car sites with fairly wide scope not just local. They are out there! Certified cars have great rates on them now and warranty.
Old 07-22-2013, 01:25 AM
  #44
Patrick Ritchie
Patrick Ritchie's Avatar
Just ran this exercise.
For similarly optioned cars I got the following results on AutoTrader.
18 or so M6 2005s w/ 1sb and Z51 and less than 50k miles.
Average price $30,123.
Low: $25,995
High: $32,995
5 or so 2008+ w/ more than 60k miles, ignored options due to low sample size.
Average price $29,119
Low: $27,000
High: $30,621
Based on this the asking price of both cars seems reasonable.
Old 07-22-2013, 03:35 AM
  #45
Stavesacre21
Stavesacre21's Avatar
Low: $25,995
High: $32,995
Low: $27,000
High: $30,621
I've never liked this comparison, because all of those numbers are based on cars that are still for sale. There's a reason why all of those cars are still for sale.
I started my 2002 almost $4000 more than I ended up selling for. Using that info, the statistics would raise the average price when running a comparison like this, although as I have mentioned, my car went for quite a bit less.
Old 07-22-2013, 09:26 AM
  #46
GuyFromLeMans
GuyFromLeMans's Avatar
Exactly!
One more time: You want a good idea of market value, check completed sales listings on Ebay.
That will tell you what buyers are willing to pay.
Not what sellers are willing to ask.
Old 07-22-2013, 03:38 PM
  #47
jrob56
jrob56's Avatar
Originally Posted by RestoRoc89
I would always go for the newer car. The least straightforward failure modes to correct tend to be those that progress with age more than with travel. An older car may be more likely to experience:
-Embrittlement, creep and fatigue of elastomeric components (e.g. leaking seals, hoses & weather strips, loose powertrain mounts, etc.)
-Creep/cracking of plastic parts...plastics inherently age poorly and the effects are accelerated with things like UV exposure and thermal cycling. As an anecdote, a friend's ultra-low mileage early C6 has far more squeaks, creaks and rattles than my 2011 car does.
-Corrosion, which can reduce heat exchanger efficiency, result in poor conductivity at electrical contacts and make fasteners difficult to remove for maintenance
Corvettes contain a staggering number of components that will deteriorate with age regardless of mileage. The components that do wear with usage tend to be a) fairly robust (thinking of the moving parts in the power train and driveline) and b) straightforward to replace (running gear, switch gear, etc.). I bet that even the driveline is more likely to require service because of a leak than due to a mechanical failure.
Regardless of the mid-cycle improvements, I would go for the newer car. Especially because of those improvements, I would go for the newer car. Good luck and let us know what you decide.
Best answer hands down I think! Even the warranties kind of reflect this, 3/36k bumper to bumper and 5/100k drivetrain if I am not mistaken.
Old 07-22-2013, 06:07 PM
  #48
Gearhead Jim
Support Corvetteforum!
Gearhead Jim's Avatar
Received 2,051 Likes on 1,362 Posts
St. Jude Donor '13
We had a 2006 and now a 2009, comparable to what the OP is looking at.
The 2006 is a good car.
The 2009 is a GREAT car.
Old 07-22-2013, 06:34 PM
  #49
JKbride
JKbride's Avatar
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
IMO, I would go with the one "Least used". In this case the older/less milage car.
If you put 25K miles on it you will have a very limited pool of buyers when you go to sell it with over a 100K on the odo. Older car with low miles will always command interest.....after all you're considering one.
In the end, it's a mechanical thing and the one with the least wear is your best bet.
Old 07-22-2013, 07:12 PM
  #50
whiteboy
whiteboy's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Well said. Could'nt have said it any better myself. When buying used, you are buying miles, regardless of the year. Granted the 09 offers slightly better horsepower. The 05 is going to give you all the horsepower you can use on the street and then some. With a 37000 mile difference in miles, how many years use is that for you? Determine in your mind the mileage that is acceptable to you, then buy the car that is the color, coupe or convertible, options that you want and you will be much happier with the car. Good Luck with the hunt. That is part of the fun. Be sure and search the Corvette Forums forsale section. You can speak with the seller and get a feeling for how he takes care of that particular car. I bought my last two Vettes here on the Corvette Forum and have been very pleased with the cars.
Old 07-22-2013, 08:38 PM
  #51
Gearhead Jim
St. Jude Donor '13
In the interest of Full Disclosure, we must note that JKbride's profile says that he has a 2005. Whiteboy has a 2006.
As mentioned in post #48 (more Full Disclosure), we have owned two Corvettes very similar to the two that OP is considering. Our current 2009 has 61k miles, and I'd take it in a heartbeat over anything before 2008 regardless of miles. There is that much difference between the years.
Not to say that you can't have fun with a 2005, but ...
Old 07-22-2013, 10:11 PM
  #52
JKbride
JKbride's Avatar
No doubt always buy the newest, nicest you can afford, but if you buy a car with 75k miles, you'll hit 100K before you know it.
As a owner who knows how my car was driven and maintained I would have no issue with having lots of miles ( in fact they are meant to be driven), but unless I knew the owner and car, I would pass on one with 75K miles, LS3 or not.
.....and yes, I have fun in my trouble free 2005 that I purchased 2 years ago with 20,100 on the odo And appreciate the previous owner kept the miles down till I came along. When mine comes up for sale it will likely have 100k miles
Old 07-22-2013, 10:33 PM
  #53
raspyc6
raspyc6's Avatar
an '05 for 30k is silly. The '09 with the LS3 FTW I say despite the miles.
Old 07-23-2013, 04:14 AM
  #54
Like dem Vettes
Like dem Vettes's Avatar
Condition is more important than miles. Not every Corvette owner does flushes and induction cleanings, for example. Check the maintenance records.
Old 07-24-2013, 01:23 AM
  #55
RestoRoc89
RestoRoc89's Avatar
If it adds any credibility, I am a reliability engineer--the guy who conducts endurance tests, analyzes field failure statistics, redesigns components for reliability growth and sets/validates likelihood of surviving warranty periods...
Quick Reply: Miles vs age
