Need Your Help Guys!
Old 08-05-2013, 08:44 AM
Brockman66
Brockman66's Avatar
Default Need Your Help Guys!
So, I went to drive the Corvette to work today and when I started the car everything was fine. As I was leaving the apartment complex's parking lot and all these codes poped up on the DIC: "Service Charging System, Service Active Handling, Service Traction System, Shocks Inoperative, Service Fuel System, Service Antilock Brakes." Also, the fuel guage on the dash drops all the way to empty and the "Low Fuel" warning displays. Car goes into reduced power mode. "Check Engine Light" is on.
I assume that the odds of all these going wrong overnight are slim to none. I'm guessing it is probably something electrical or maybe a wheel position sensor or something. I'll keep the post updated as I'm taking it to the dealer ASAP.
Old 08-05-2013, 08:49 AM
genolan
genolan's Avatar
Battery
Old 08-05-2013, 08:52 AM
mcandrew67
mcandrew67's Avatar
Received 1,013 Likes on 599 Posts
2016 Corvette of Year
2015 C6 of Year Finalist
Originally Posted by genolan
Battery
when it starts to go bad, all these things commonly pop up, and it is generally related to a battery on it's last legs.
Old 08-05-2013, 08:54 AM
Brockman66
Brockman66's Avatar
How is it the battery? The car started perfect, didn't even hesitate to turn over.
Old 08-05-2013, 08:57 AM
Mad*Max
Mad*Max's Avatar
Received 1,508 Likes on 820 Posts
Old 08-05-2013, 09:03 AM
mcandrew67
mcandrew67's Avatar
Do a search on here, many many owners had the exact same issue and the car started, once the battery was replaced it was fine.
Old 08-05-2013, 09:18 AM
myfunz
myfunz's Avatar
Old 08-05-2013, 09:21 AM
jimmie jam
jimmie jam's Avatar
Good to know, my original battery is 6 years 8 months old.
Old 08-05-2013, 09:30 AM
mcandrew67
mcandrew67's Avatar
lucky you, I am on my 3rd one, I ended up getting the Optima Yellow top.
Old 08-05-2013, 09:34 AM
Brockman66
Brockman66's Avatar
Thanks guys, I have an appointment at the dealer at 2:00, I'll update the thread as I find out information. Hopefully, for my wallet's sake, it's just the battery. I hope it's not anything too major.
Old 08-05-2013, 10:09 AM
icntdrv55
icntdrv55's Avatar
I'm not gonna claim that I'm an auto electrical tech, but I could see where a battery could have sufficient amperage capacity to start a car, but have a bad/sulfated cell and not be able to supply the correct voltage. Modern transistor/circuit board technology is exquisitely sensitive to voltage spikes.
Old 08-05-2013, 10:11 AM
SkyTopp
SkyTopp's Avatar
correct
Old 08-05-2013, 01:18 PM
Brockman66
Brockman66's Avatar
Well guys, just had the battery tested at Autozone and it tested "good." So it's off to the dealer at 2:00 to have it checked out.
Old 08-05-2013, 01:35 PM
Hameister
Hameister's Avatar
2015 C6 of the Year Finalist
If I were you, I'd be thrilled with a battery life of nearly 7 years, and I'd replace it immediately.
Unless of course, you're fond of getting stuck at the worst possible time, because that's always when batteries die.
Old 08-05-2013, 01:37 PM
Top_Fuel
Top_Fuel's Avatar
Not trying to make you freak out, but I remember a similar story in THIS thread.
Old 08-05-2013, 02:35 PM
Brockman66
Brockman66's Avatar
Thanks for the post, I doubt that I have the clogged condenser hose and I'm already out of warranty as the car is a 2005 with 174,XXX miles. Hopefully the Autozone guy was wrong and it is actually the battery.
Brockman66
Brockman66's Avatar
For $96 an hour they better find the problem!
To Need Your Help Guys!
Old 08-05-2013, 02:42 PM
mcandrew67
mcandrew67's Avatar
For $96 an hour I would have changed the battery anyway and then if it wasn't the issue go to the dealer.
Old 08-05-2013, 03:05 PM
Mad*Max
Mad*Max's Avatar
and with zero warning!
Old 08-05-2013, 03:06 PM
okie08vette
okie08vette's Avatar
9 times out of 10 what you describe is the battery.
Quick Reply: Need Your Help Guys!
