***All-new Cree LED Exterior light upgrade for the C6 by Radioflyer Innovations***
Old 08-05-2013, 11:24 AM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Default ***All-new Cree LED Exterior light upgrade for the C6 by Radioflyer Innovations***
This is the first Plug-and-Play high-power LED solution for All the Exterior lights on the C6 corvette using Cree XP-E LED technology. These LEDs are the latest and brightest in the industry used in everything from tactical flashlights to emergency vehicle warning lights.
Compare (reverse lights) to the weak factory bulbs:
Also included with the kit are the first production DRL hyperflash relay harnesses. These use a resistor to simulate factory load for the turn signal but shut off after a few seconds in DRL mode to prevent the resistor overheating and damaging non-metallic components.
The kit includes:
(2) 3157 Amber Bulbs (for DRL/Signals)
(2) DRL hyper-flash harnesses
(2) 194 Amber marker bulbs (for front marker lights)
(2) 194 Red marker bulbs (for rear marker lights)
(4) 3157 Red bulbs (for park/stop bulbs)
(4) Load resistors for rear bulbs
(8) T-tap splices (for easy installation of rear load resistors)
(2) 3157 White bulbs (reverse light bulb)
(2) Cree 194 white bulbs (for tag lights)
Don't waste your money on cheap LED bulbs that are dim or that use white LEDs behind colored reflectors. Get the proper part and bring your C6 into the modern age with Radioflyer's Cree LED package.
Order yours today at the special Pre-Production price of just $365 (normally $395):
http://www.shop.radioflyerinnovation...ackage-047.htm
Old 08-06-2013, 09:50 AM
TheRadioFlyer
Supporting Vendor
ttt
Old 08-07-2013, 11:14 AM
TheRadioFlyer
Supporting Vendor
morning bump
Old 02-20-2014, 12:09 PM
GC456
GC456's Avatar
How are the resistors installed?
Old 02-20-2014, 12:21 PM
TheRadioFlyer
Supporting Vendor
We use t-taps.
With the flasher being computer controlled, there's no way around having to use load resistors to prevent hyper flash.
Old 02-20-2014, 01:40 PM
2012Z06
2012Z06's Avatar
Do you have an option for switchbacks on the DRL's
Old 02-20-2014, 02:06 PM
TheRadioFlyer
Supporting Vendor
We certainly do.
http://shop.radioflyerinnovations.co...s-3157-055.htm
To ***All-new Cree LED Exterior light upgrade for the C6 by Radioflyer Innovations***
Quick Reply: ***All-new Cree LED Exterior light upgrade for the C6 by Radioflyer Innovations***
