Manual Trans Fluid Change Questions
i decided to change out my differential and trans fluid in my 09 mn6 today. with only 12k miles on the car the differential fluid was muddy and dark. glad to have changed it. got just about 2 quarts in. and about the same amount out.
as for the trans though, as soon as i removed the FILL plug the fluid started pouring out. i would estimate about a half quart perhaps that came out just from removing the fill plug. keeping in mind the car was level. i probably drained about 4 quarts total but was only able to get back in roughly 3.5 quarts. is this acceptable? did the factory over fill? it must have been filled past the fill line if it came out of that plug right? or is it possible that the fluid expanded because it was warm and i put it back in cold? would that account for that inaccuracy?
i also started the car, put it in gear, and let the wheels spin for a few moments to circulate the fluid and then when i rechecked the level it was still at the fill plug hole level. but then i noticed that the "Service active handling" and the ABS malfunction light came on after spinning the wheels in the air. The error message has since gone off after driving it normally on the road.
did i do anything wrong?
The active handling will come on and you will get warning lights but did you turn traction control off before you ran it up in the air? You did not hurt anything.
Everything you did was correct, by the way and I would say that the trans was over filled slightly. I would rather have it that way than too low though.
also, how would i fill it more than the fill hole if it just come out? how did the factory do it?
I agree with the other poster too that the fluid was warm and had expanded. You filled yours cold so it would do the same thing once you warmed it up and drained it.
My 07' has 11K miles and I just did the change yesterday. The owner's manual says that my car (Z06 w/T56 trans) takes 4.5 quarts. Many responses to the DIY thread indicate that the trans generally takes only 3.25 to 3.75 quarts to bring it to the fill plug. That leads me to believe that 1.25 to .75 quart(s) of the old fluid does not drain? I drove the car around a long block to warm up the trans fluid thinking that more fluid would drain if it was warm.
Like the OP, I opened the FILL plug first and fluid shot out all over my face. (Luckily the fluid temp was just above ambient.) Ultimately, FIVE (5) quarts came out!
Then it only took 3.75 quarts of fresh AMSOIL Torque Drive Synthetic ATF. Like the OP I was puzzled. My guess is that, it was a little bit over filled and the fluid volume changed due to the slight heat? It is still sort of a mystery and a pretty common mystery. Also, like the OP, I started the car and cycled through some gears while it was in the air and rechecked.
Either way, the fluid was milky and I am glad to have it changed. What I don't want is leftover old OEM fluid mixed with the new AMSOIL.
the light came on because only 2 wheels were turning. don't forget to do @ 5-10 figure 8's to let the fluid get into the clutches in the diff or it will make NOISE
OK ... but why would you change the transmission fluid on a manual It's not listed in any of the maintenance schedules in the manual :
Manual Transmission Fluid
It is not necessary to check the manual transmission fluid level. A transmission fluid leak is the only reason for fluid loss. If a leak occurs,
take the vehicle to the dealership service department and have it repaired as soon as possible. See Recommended Fluids and Lubricants on page 443 for the proper fluid to use.
Auto trannies ... yes every 50K miles, but not necessary on a M6
LPT2011 is online now Report Post Reply With Quote
The unit is sealed only in the sense that it has seals and should never lose any fluid. That doesn't mean that you shouldn't maintain it if you choose to.
i was just going to change the differential only but figured why not do the trans as well since it was up in the air and it was simple enough. trying to improve shift quality.
There are a host of reasons to change the fluid in a manual transmission. Besides normal wear and tear on the fluid, usually fresh fluid provides a smoother shift. If I had the means (place to work, tools), I would change my fluid early as well.
I really would believe that shift "smoothness" has infinitely more to do with your clutch mechanism than the transmission fluid
Premium Supporting Vendor
I suspect the tranny was a combination of the factors you mention. The tranny will take about 3.5ish qts, so you are fine.
I forget the exact parameters that cause either service active handling or active handling warming up messages, but when the front and rear wheels spin at different rates, that is one of them. As long as the warning doesn't come back on the street, you should be fine.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
