C6 Coupe Rear Clunk Troubleshooting
Cruising
I have a 2007 C6 Base Coupe (Manual) with around 50,000 miles that recently started to make a "clunking" noise from the rear end (can’t tell if it is from left or right side). It will occur over small inputs at low speeds. It also makes noise on a smooth road if the car lurches forward when I purposely do a hard shift.
However, I am NOT able to reproduce the noise with the car parked by pushing down on the rear end or pushing it forward. I also tried to shake the exhaust, but that does not reproduce the noise either.
I raised the rear end with a jack and tried to wiggle the rear tires left to right and up/down, but it feels tight. There is no slop.
I read through the forums and decided to change my differential fluid to the recommended Dexron 75W-90 (per the GM TSB). However, this did not resolve the issue.
I visually inspected all the rear end bushings and tightened the suspension bolts (sway bar, links, control arms) and everything seemed OK. I also sprayed some white lithium grease on the rubber bushings, based on another thread comment. However, the car still clunks.
Does anyone else have other suggestions of what to look for or try? I don’t want to take it to a dealer, because I know I can fix it myself once I find the noise source. I just don’t want to start randomly replacing parts.
Did you do this?
From the TSB;
"Once the differential fluid has been changed, the vehicle must be driven in 8-10 tight figure eight maneuvers to heat the fluid and allow the fluid to be worked into the clutch plates."
From the TSB;
Received 8,928 Likes
Bill
Cruising
Clunk
I have not tried to tighten the rear axle nuts, but I will look up the proper torque and see what happens.
I did perform the 8-10 tight figure eights after changing the differential fluid.
I looked through the dealership history from the past 2 owners and it appears the rear sway bar links were replaced after 25k miles.
I just want to reiterate that I am not able to reproduce the clunk with the car parked when I try to bounce the rear end or rock it fore/aft. Does this rule anything out or point me in a certain direction? I am thinking ball joint, because I had a similar clunk noise on my 09 G8 GT and that was the fix.
Thanks for the suggestions.
Hey 0260,
If there is anything I can do please let me know. If you want to send me your VIN I can see if there are any open service related announcements.
Kelly J.
Chevrolet Customer Care
Kelly J.
Cruising
Clunk
Based on a suggestion from another thread I lubricated the half shaft splines and tightened the rear axle nut to 150 ft/lbs, but the clunk is still present.
My next step is to briefly disconnect the rear sway bar to confirm if the noise is eliminated.
Received 1,500 Likes
Be careful with re-tightening the axle nuts as they are supposed to be replaced and not re-tightened. Also, there are numerous threads on this and I read that you if you keep re-tightening you can break the axle.
Take him up on his offer ! There was a service bulletin out on mine. Had the same problem with my '07 automatic. They changed rear end oil and put in some additives and no more noise.
I'm having the same exact issue with my A6 (clunk only on hard shifts and shift down to first while stopped) - I'm pretty sure its the rear control arm bushings but would love a second opinion from someone who had same symptoms and fixed it
I had this problem a few months ago, the dealer was sure it was the end links since they were stock and its a common problem. Replaced endlinks, swaybar bushings,lowering bolts, tightened all the controlarm bolts, tightened and locktited the rear axle nut but was still there.
Took it up on a lift again and saw a drop of oil coming from a rear shock and turned out that the left rear shock was shot and the cause of the clunking in my case. Each time the shock was extending it made a clunk since it had extremely fast rebound because it was blown.
Landru (01-21-2017)
Based on my vast experience with cars of much simpler technology than these, I would have a look at the universal joints. There could be some looseness in one of them making it clunk every time you put a little power to the drive train, taking up the slack in the worn joint(s). Or you could do eight or nine figure eights in the opposite direction and see if that helps.
That same noise happened to me, I sprayed white lithium grease on the bushings and it went away, it started again a couple of months after that, my question is, where can I purchase the rear suspension arms bushings? Is there a kit? Help.
My thoughts exactly. I had a C6, and mine did the same thing. They may be installed tightly, both top and bottom of the end link, but they still may be loose within the link itself. Does it usually happen when going over a bump? That's when mine made the worse sounding "clunk". I replaced all four.
I think you are going to find that your lifting bolt bushings have deteriorated and you are metal to metal.
I had the exact same issue.
Jack it up and check the ends of the jacking/lifting bolts on each end of the mono leaf spring, there should be a rubber bushing where it pushes down on the control arm, it's very hard to see. it will deteriorate and you will have a metal to metal clunking noise in the rear when the suspension flexes while driving.
I hope this helps
BMF
I hope this helps
BMF
