How many of you driving at night get flashed brights
Old 08-10-2013, 10:50 PM
Ozarkwoods
Ozarkwoods's Avatar
Default How many of you driving at night get flashed brights
I have had my car out at night...I have had many cars flashing their lights on bright to signal me to change to dims.....problem they already are on dim..is it the HIDs?...maybe I need to adjust them down..
How many of you are experiencing the same?
I hate p*ssing off people..
Old 08-10-2013, 11:04 PM
calemasters
calemasters's Avatar
The headlamps are properly set at the factory. Others can flash all they want. The HIDs do have higher intensity that sealed beams or halogens.
Old 08-10-2013, 11:06 PM
c6vette142dude
c6vette142dude's Avatar
I do know that some of these newer cars have lights that blind the heck out of me, and they're not even the "brights". Making it worse, there are some aftermarket companies that are coming out with lights that equal 10 'suns' lol. I just try to look down and to the right. Of course some of them might be flashing you to warn you of LEO's up ahead.
Old 08-10-2013, 11:37 PM
Knob Jockey
Support Corvetteforum!
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
You can dial them downward a little bit, especially the driver's side.
Then do the 'test' where you drive down a street with parked cars and see if they're still hitting the windshields.
Old 08-10-2013, 11:54 PM
Sunnyvale Dave
Sunnyvale Dave's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
Never has happened to me.
Old 08-10-2013, 11:59 PM
Toxicscream
Toxicscream's Avatar
Happens all the time to me, especially the truckers flash me. I just leave high beams on till they flash or till im close enough they will notice then lower.
Old 08-11-2013, 12:18 AM
michaelinmech
michaelinmech's Avatar
ummm . . . .why? Why not dim them to regular if you see the truck coming?
Old 08-11-2013, 05:44 AM
CaryBob
CaryBob's Avatar
Never happened to me, but I rarely use high beams.
Old 08-11-2013, 07:18 AM
C6ToGo
C6ToGo's Avatar
Received 1,116 Likes on 693 Posts
Happened to me quite often till I adjusted down slightly. Never again and wasnt enough to change MY visibility.
Old 08-11-2013, 07:57 AM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
That's the right answer. The C6 is very low and has a very good light pattern and so the HIDs should never be too bright except coming over hills/bumps. You really have to point the car up into the air to get light up to a regular car's windows if they are aimed correctly. You don't need to blind other drivers so they drift into your lane to be able to see. Adjusted straight out level gives great visibility on level roads and no one complains.
Old 08-11-2013, 09:10 AM
z51vett
z51vett's Avatar
Happens to me all the time when I flash the brites they get it.
z51vett
Doug
Old 08-11-2013, 10:04 AM
Garibaldi
Garibaldi's Avatar
Same here. BUT I could see it happening if you were traveling uphill and they came over the top at the same time. The low beams are fairly bright and the sharp cutoff may induce the other driver to flash you. I have Corvette Mods' low and high beam replacements which are much brighter, and I've never been flashed.
GP
Old 08-11-2013, 10:09 AM
Duro
Duro's Avatar
z51vett
Doug
Old 08-11-2013, 10:10 AM
Steve_R
Steve_R's Avatar
Received 3,289 Likes on 1,399 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
Never to me. Leaving your brights on until an oncoming car flashes theirs at you is simply being a dick.
red2012
red2012's Avatar
z51vett
Doug
Exactly my scenario.
Old 08-11-2013, 12:38 PM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
It is possible that the projectors may have moved since originally aimed by factory. To ensure that they are correctly aimed, Line the car up from a wall 20-15' away.
The pattern should look like this:
If your car has had suspension or lowering modifications, your vertical adjustment may need to be lower than pictured.
To How many of you driving at night get flashed brights
Quick Reply: How many of you driving at night get flashed brights
