New Coolant - Flush or Drain -
Old 08-17-2013, 10:05 AM
Silverado Desperado
Silverado Desperado's Avatar
Default New Coolant - Flush or Drain -
Installing new water pump... is there anything special to do when putting in new coolant?
Do I just remove the lower radiator hose and water pump and let it drain, and then refill with 50/50 mix of Dexcool?
Or do I need to do something more to flush out all the old coolant before putting in new coolant?
Old 08-17-2013, 10:40 AM
beepster
beepster's Avatar
Old 08-17-2013, 10:50 AM
truckplay
truckplay's Avatar
to flush it you need to get it all out so you need to run the engine while still supplying water to it. Once clean water starts coming out then you add the coolant. Don't forget to catch the old coolant and dispose.
To New Coolant - Flush or Drain -
Quick Reply: New Coolant - Flush or Drain -
