Exhaust experts needed for advice!
Got a new 2012 GS with every possible option except for the NPP! Would like to add a dual mode system.
have some questions that I would appreciate answering..
Is there such a "plug and play" mufflers or i have to do cutting and welding if i am replacing the standard mufflers?
Any one knows of a "wider" sound range for an after market system compared to the factory NPP? I.e. a quieter (or as quite) closed mode and louder open mode.. Guess the BB fusion is way louder on both ends? Does any one knows of a "one mode system/ or no valves system" that has as quite INTERIOR sound on low RPMs as the stock?
Any links to compare the sounds/ loudness of standard vs npp vs aftermarket exhausts? Sound/ videos/ or even db charts?
Any one knows of a place can install the mufflers and the controller ( thinking sunset orange creations) in Chicago area? Any info about how long it takes or how much it costs?
Thanks much for the input in advance,
Al.
Al.
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Plug and play NPP mufflers for your car would be 2009-2013 NPP mufflers from a standard coupe, convertible or grandsport coupe or convertible. The Z06 and ZR1 mufflers will require some cutting and or fabrication to connect o your mid pipe.
