Weight of Grand Sport Coupe
Old 09-10-2013, 04:01 PM
bill gsport
bill gsport's Avatar
Default Weight of Grand Sport Coupe
I thought I've read some weight specs on the C6 Vettes that said they were about 3,200 lbs or so. When getting my car inspected this week, my friend pointed out the door sticker showing weight of over 3,800 lbs. Seems a little heavy (not that I'm going to rush out and sell the car or anything). Just curious...anybody have more info?
Old 09-10-2013, 04:08 PM
Seadawg
Seadawg's Avatar
a quick search found this
http://forums.corvetteforum.com/c6-c...rt-weight.html
Old 09-10-2013, 04:15 PM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
The 3800 is probably the gross vehicle weight, meaning the car, two people, luggage, and a full tank of gas. The curb weight, meaning just the car, is about 3200-3300 lbs. Pretty light car. And the Z06 is even less.
Old 09-10-2013, 04:59 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Curb weight on the base C6 coupe is 3208 and is 3311 on the GS coupe.
To find the actual weight of a particular car, take the Gross weight( found on the door label) and subtract the maximum cargo(includes people) weight(found on the driver's door jam label).
For example, my 2009 Z06 has a curb weight of 3175, according to GM, but that is for a no optioned car. My car is a 2LZ, NAV and chromes.
Drivers door label shows the GVWR as 3651 pounds and the drivers door jam label shows the max cargo weight of 423 pounds.
That means my particular car weighs 3228 pounds with full fluids but no driver. The options added 53 pounds.
Old 09-10-2013, 05:22 PM
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
it's around 3333lbs, 100lbs heavier than a narrow body C6 (3212lbs). Z06 is 3185lbs. ZR1 is around weight of a GS.
Old 09-11-2013, 12:19 PM
bill gsport
Thanks, guys. As always, your info makes me look like I know what I'm talking about!
Old 09-11-2013, 04:04 PM
TLS_Addict
TLS_Addict's Avatar
You want a real weight? Take the car to a scale.
Old 09-11-2013, 05:01 PM
not08crmanymore
not08crmanymore's Avatar
It's lighter than the C7!!
Old 09-11-2013, 07:40 PM
carolina cutie
carolina cutie's Avatar
Where would you find one that is accurate?
Old 09-11-2013, 08:20 PM
old motorhead
old motorhead's Avatar
Received 1,339 Likes on 947 Posts
Some truck stops have them. All public grain elevators have certified scales. I'd call before showing up at a grain elevator in a vette though
Old 09-12-2013, 10:17 AM
haljensen
Support Corvetteforum!
haljensen's Avatar
I used the the local shop that did the SCCA weights and alignments.Call around and see who the racers use.
My '05 Z51 M6 1SB was checked for corner weight, total weight was 3251# with 1/4 tank of gas and all other fluids full. 1748# Front and 1503# Rear. 54% F & 47% R
My '08 Z51 A6 3LT was checked also, total was 3266# with 3/8 tank of gas and all other fluids full. 1665# Front and 1601# Rear. 51% F & 49% R.
To Weight of Grand Sport Coupe
Quick Reply: Weight of Grand Sport Coupe
