My C6 is Eating Left Turn Signal Bulbs
Every six to seven months I have to replace my left turn signal bulb. Anyone else having this problem? I still have the original bulb in the right signal. Is it because you make more left turns?
That's funny.....haven't seen that before.
Probably because it takes longer waiting to make left turns so the bulb gets more "on" time and gets hotter.
Just thinking out loud.
I would think you have a bad 'socket' - or perhaps a loose electrical connection to the socket. IMHO, you should check both, as turn signal bulbs last much monger than 6 months.
Make sure you are not getting moisture in and around the bulb. A friend had a C5 and it had a small hole in the housing and it would get wet and blow the bulb. The C6 bulbs are exposed even more.
Clean and inspect sockets and wiring as well.
Takes too long to make 3 right turns.....
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
When I first joined the CF back in 2005, I vaguely remember a run of burnt out directional bulbs and I believe the cause was a bad socket. But that a long time ago. Don't know if that helps.
I also think they were at that time replaced by the dealer under warranty but that wouldn't apply in your case now. Good luck.
Make sure it's exactly the right number bulb. I was going through bulbs like crazy, then bought the exact bulb and the problems stopped.....
Replace the socket. They tend to over heat as the drl is also on. Use a dielectric past sparingly. I never run my drl and my C6 has all original bulbs. My Cadillac SRX on the other hand eats bulbs no matter what I have done to stop it.
C5s also had this problem...
Moderator
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I experienced the same thing with my C 5. After replacing several bulbs I took it to the dealer. The socket was replaced (under warranty) and that took care of the problem. I have had no problem with the C 6.
I've not had the problem with my C6, but I had to replace one on my C5. But I had it 11 years, so no biggie. And my Corvette specialty shop did it free, just $5 for the bulb. Probably been a fortune at the dealer.
Some people don't use turn signals just to save the bulb. That too is a terrible idea, and illegal in most places.
I can't offer any technical input to solve your problem, but you may find this interesting.
The conclusion was that it does indeed save gas to make all right turns, even though it's a longer distance. And they had quantitative data to prove it. But it takes more time. Arguably, it's also safer.
I had the same problem with my C5 and had to replace the socket and harness, was around $50.00 through the dealer for the part. I did the change myself.
I would start with putting dielectric grease in the socket and see if that solves your problem, if not it is probably the socket/harness. Good luck
Hey G,
A few members are saying this has been a concern before. I am happy to run your VIN for open service announcements. PM me with your VIN and we can go from there. Keep us all posted,
Kelly J.
Chevrolet Customer Care
Kelly J.
