Help with codes, Please
Had this problem before, http://forums.corvetteforum.com/c6-s...sometimes.html
But it started acting up again and I got some codes when I ran a scan, first set of codes engine just cranks, won't start. Then about 30 min later it fires right off so I run another scan everything same but #6, need help with where the connectors are located.
9/22/2013 06:24:28 Chevrolet Corvette 2008 1G1YY26W2851 None Off
1 Driver Door Module
B1420 Device Voltage Malfunction
2 Driver Door Switch
B1327 Device Power Circuit Low OR Battery/Source volts low OR Source/Battery Voltage Low OR Source/Battery Voltage Too Low OR Device Power 1 Circuit Low
3 Driver Position Module
B1327 Device Power Circuit Low OR Battery/Source volts low OR Source/Battery Voltage Low OR Source/Battery Voltage Too Low OR Device Power 1 Circuit Low U1000 Class 2 Communication Malfunction
4 Passenger Door Module
5 Body Control Module
B1325 Control Module Power Circuit
6 Instrument Panel Cluster
U1301 Class 2 Communication Circuit Short to Battery
7 Supplemental Inflatable Restraint
B0065 Driver Pretensioner Deployment Loop Open
9/23/2013 07:03:51 Chevrolet Corvette 2008 1G1YY26W2851 None Off
No diagnostic codes retrieved
Has the car ever had the PAL installed (Ipod adapter)? It connects to the Class 2 data bus wire under the dash, above your left foot when sitting in the drivers seat. If it was removed, maybe the wire is shorting causing a loss of communication on the Class 2 data bus.
No PAL installed, but they did replace radio under warranty. Do I need to remove cover with footwall light to get to wire?
BTW, the radio is tied into the class 2 bus, did your issues start right after the radio head unit replacement?
Radio was replaced in 08. But I'm thinking it is a loose or bad connection, it runs great if it starts. And it has always started after a few attempts, but I feel my luck is running out.
